prometheus Posted June 16, 2013 Share Posted June 16, 2013 Been searching the forum and found guides on removing the wheel arch liner, after having a disagreement with the bottom 2 bolts I eventually got it pulled off enough to see the side light connector. But man you need small hands to try and remove it. Which I failed to do and gave up, I was able to turn it clockwise and it seemed loose but wouldn't come out, my question is how do you remove it? Does it only turn a quarter and then just pull out? When I tuned it past a quarter it seemed to tighten up again. Driving me nuts and need to replace the bulb as MOT is soon. Quote Link to comment Share on other sites More sharing options...
KyleR Posted June 16, 2013 Share Posted June 16, 2013 Only a 1/4 turn if I remember correctly. Give it a good wiggle, chances are it's just not perfectly lined up to come out. 1 Quote Link to comment Share on other sites More sharing options...
Sam Mcgoo Posted June 16, 2013 Share Posted June 16, 2013 1/4 turn anti-clockwise and a gentle pull/wiggle. Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted June 17, 2013 Share Posted June 17, 2013 Grip it firmly, give it a twist and a good yank Quote Link to comment Share on other sites More sharing options...
Dave-350 Posted June 17, 2013 Share Posted June 17, 2013 Do what I did and wait until you smash the front end and the wheel arch liners fall off, perfect opportunity to replace your sidelights :thumb: Quote Link to comment Share on other sites More sharing options...
