Import window switch
Daryl
While i was waiting for the car to be finished in the bodyshop, i treated it to an import window switch(one touch up and down both sides), fitted it Friday, and found it does not work on the passenger side. :rant:
Is there anything that can be done to make it work, or is it an issue with the ECU or something?
You sure you got an import switch then?
Buster and I have done a few now - you only need change the passenger side switch and you get the one touch operation (well we did)
Last one I did was mine and the only problem is on 1 touch up the window gets to the top then comes down about 4 inches :lol:
Need to do a window reset that should sort it out (I hope)
  • 3 years later...
Am I reading this right....you just need the passengers side switch and not the drivers (double) to get the one touch feature....working from the drivers side?
Not bothered if the passenger has to hold the button 😂
