Reversing light cable colour & location for reversing camera
EvansJD2112
Finally got round to fitting my reversing camera.
Pulling the cables through was quite easy thanks to the guides on here.
Being lazy, I only removed the one piece of trim at the back of the boot.
I know from the guides that the reverse power cable is green with silver trim and notice in the mass of cables right in the middle of the boot (above the rubber grommet you pull the cables through) there is a cable with the same colours.
So... is this the right cable?
I took a photo, but the upload to photobucket failed and I didn't notice before re-fitting trim. :-(
I need to get some more scotch locks tomorrow, so not been able to "give it a try" yet
Thanks
If i remember correctly when I did mine, its not the middle one, its one in the near side corner (by the reverse lamp). Dont take my word for it though, but I'm pretty sure i almost made the same mistake :ninja: haha
Thanks
You've probably done it by now, but no, the lime green/silver cable in the middle of the boot doesn't seem to be the same cable.
I first connected here and got no signal on the screen, when I moved it to the location suggested in BM's guide it worked fine.
interestingly my camera seemed to work totally fine without a ground point :shrug: I can only presume it was somehow grounding itself through the video signal cable, but I connected the ground wire in the end anyway.
Edited by cs2000
