Nismo V2/V3 and headlamp washers?
longsh07
Hi Guys,
Trying to decide on a body kit for my 350z and I really like the V2 and V3 Nismo front bumpers but Im concerned about the headlamp washers.
Ive done some research and some are saying you can cut holes for them while others say because of the different shape the washers wont stick out enough and so they should just be removed/disabled.
If they we're removed/disabled, would this not be an MOT failure?
Hope someone can shed some light, maybe provide some pics of V2/V3 with washers cut out or let me know if they have had any issues at MOT time.
Cheers.
Ah so the washer jet is actually attached to the bumper rather than anything behind it.
So in theory they should fit fine to any bumper with a flat surface for them to mount on.
Quoted for reference:
The head light washer positions were next. (time and care Required here. Mearsure twice cut once)
I found that the washer apetures bottom edge ran parrallel with the top edge of the reflector which made the positioning a lot easier. A square was used to transfere the veritcal line which was in may case was 30mm from the corner of the reflector. The bottom edge of the washer apeture was 50mm up from the top edge of the reflector (see Picture) (These measurements are individual to this bumper and may vary to others but it's a good starting point). A simple cardboard template was scribed from the original bumper and used to trace the outline for the new jet location. A 10mm drill bit was used to remove material in the corneers of the opening and a jig saw with a fine toothed blade to cut out the remaining material. It is best to air on the small side when cutting out and remove any excess material to get the perfect fit. (You can always remaove material but cant put it back). Pcictures 3, 4 &5 show the washer jet in position.
It's worth noting that the bumper needs to be a specific thickness to allow the washer jet retaining clips to hold it in place. I needed to grind away excess material for this to happen.
The washer jet housing bracket has been integrated into the bumper so a 6mm driil bit was used drill out the locating holes and bracket fitted.
The next 4 pictures just show the washer jets in place.
Edited by longsh07
Just something interesting while researching:
Vehicles equipped with High Intensity Discharge (HID) or LED dipped beam headlamps may be fitted with headlamp washers and a suspension or headlamp self levelling system.
Where HID or LED dipped beam headlamps are fitted, switch on the headlamps and check the operation of any headlamp levelling and cleaning devices fitted.
Keyword, MAY. So surely that means if they are fitted they have to work, but if they are not fitted then there is no issue?
Source: http://www.motuk.co.uk/manual_170.htm
