bpmjames Posted June 14, 2013 Share Posted June 14, 2013 (edited) Ok so i trial fitted my bmw wheels today and the offset is a little off, i have about 20mm of tyre showing outside the arches. Im running 20mm h&r pcd adaptors. Oh and yes im aware it needs lowering thats next on the list. Heres a pic or few, anyone have any ideas what i can do about the fitment? What about subtle overfenders or extended arches? Sent from my GT-N8010 using Tapatalk HD Edited June 14, 2013 by bpmjames Quote Link to comment Share on other sites More sharing options...
lmc Posted June 14, 2013 Share Posted June 14, 2013 By the time you've lowered it they should tuck in the arch nicely Quote Link to comment Share on other sites More sharing options...
bpmjames Posted June 14, 2013 Author Share Posted June 14, 2013 Yeah but ill then have massive camber...also not good Sent from my GT-N8010 using Tapatalk HD Quote Link to comment Share on other sites More sharing options...
Tarmac@TarmacSportz Posted June 14, 2013 Share Posted June 14, 2013 That is seriously aggressive !! I love it Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted June 14, 2013 Share Posted June 14, 2013 Those wheels do look good on the Zed, I remember seeing them on another Zed too... Quote Link to comment Share on other sites More sharing options...
lmc Posted June 14, 2013 Share Posted June 14, 2013 Yeah but ill then have massive camber...also not good Sent from my GT-N8010 using Tapatalk HD From those pics it doesn't look like the camber will be that bad. Only other option is Narrower tyres and the stretched look Quote Link to comment Share on other sites More sharing options...
tez162003 Posted June 14, 2013 Share Posted June 14, 2013 it shouldn't be too bad once you deck it. when mine is jacked up my rear wheels must sit out a good inch and a half plus haha. I have about 5 degrees of rear camber to tuck them under lol Quote Link to comment Share on other sites More sharing options...
bpmjames Posted June 14, 2013 Author Share Posted June 14, 2013 it shouldn't be too bad once you deck it. when mine is jacked up my rear wheels must sit out a good inch and a half plus haha. I have about 5 degrees of rear camber to tuck them under lol 5 degrees is a mental amount of camber we don't even run that on our race car on slicks. Thanks for the comments guys. Can anyone recommend me some coiloivers that are reasonably comfortable? Also some arch extensions? Sent from my C6603 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
marzman Posted June 15, 2013 Share Posted June 15, 2013 I love it... looks awesome. Quote Link to comment Share on other sites More sharing options...
CrumbMC Posted June 15, 2013 Share Posted June 15, 2013 (edited) it shouldn't be too bad once you deck it. when mine is jacked up my rear wheels must sit out a good inch and a half plus haha. I have about 5 degrees of rear camber to tuck them under lol Yikes. don't know which one is yours but the suspension set-up on the left hand car makes me want to roll my face around on my keyboaasdfGFDGAHGSDGhdh Edited June 15, 2013 by CrumbMC Quote Link to comment Share on other sites More sharing options...
Dblock Posted June 15, 2013 Share Posted June 15, 2013 Like this? Used to be a member on here. Or still is. Awesome car. Quote Link to comment Share on other sites More sharing options...
DoogyRev Posted June 15, 2013 Share Posted June 15, 2013 Like this? Used to be a member on here. Or still is. Awesome car. +1 Quote Link to comment Share on other sites More sharing options...
bpmjames Posted June 15, 2013 Author Share Posted June 15, 2013 Any idea who's it is? Love the comment about rolling face around on the keyboard haha I actually lol'd Sent from my C6603 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
tez162003 Posted June 15, 2013 Share Posted June 15, 2013 Haha roll your face around the keyboard lol Mines the one on the left however tyre wear is an absolute bitch! Quote Link to comment Share on other sites More sharing options...
bpmjames Posted June 15, 2013 Author Share Posted June 15, 2013 Haha roll your face around the keyboard lol Mines the one on the left however tyre wear is an absolute bitch! Just buy cheap tyres? Sent from my GT-N8010 using Tapatalk HD Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted June 15, 2013 Share Posted June 15, 2013 Haha roll your face around the keyboard lol Mines the one on the left however tyre wear is an absolute bitch! The normal looking one on the right is mine Quote Link to comment Share on other sites More sharing options...
Arran Posted June 15, 2013 Share Posted June 15, 2013 HSD coilovers are very comfortable aswell as having a lot of adjustment Quote Link to comment Share on other sites More sharing options...
bpmjames Posted June 15, 2013 Author Share Posted June 15, 2013 I was looking at hsd Arran. Would you go for the monos or dualtechs? Sent from my C6603 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
Arran Posted June 15, 2013 Share Posted June 15, 2013 I went for the Dualtechs, reason being as they have rubber top mounts as opposed to pillowballs so are more compliant and comfortable, the damper is twin tune not monotube so there's a layer of protection for the piston inside especially on our roads and conditions, the inboard rear spring setup is like oem works like standard, also the rear shock towers aren't designed to have a full coilover so the load could potentially cause the towers to fail. Much like the E36 and 46 BMWs, used to have a 36 so followed the same procedure Brilliant coilovers though! 14 way damping adjustable, loads of height adjusting available, spring preload adjustable aswell. Good thing about these are the design when lowered, no matter how low you go you won't bottom out as the travel always stays the same Quote Link to comment Share on other sites More sharing options...
choptop Posted June 15, 2013 Share Posted June 15, 2013 Like the look of those wheels. Sweeeeeet No idea on the suspension front for the Zed. Quote Link to comment Share on other sites More sharing options...
bpmjames Posted June 15, 2013 Author Share Posted June 15, 2013 From what you have said there Arran I think I'll go for them. What about camber adjustment? I've seenough rear camber arms but nothing about front camber adjustment? Sent from my C6603 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
S1 HNK Posted June 15, 2013 Share Posted June 15, 2013 Wheels look pretty bad, with all the lovely wheels available why choose the ones off a 7 series. They don't even look good on that! Quote Link to comment Share on other sites More sharing options...
bpmjames Posted June 15, 2013 Author Share Posted June 15, 2013 Because I already had them from my Beemer and if you'd read the rest of the thread you'd realise that they won't look like that when I'm done with it. There's a saying you know. If you don't have anything nice to say then don't say anything at all. I appreciate opinions and constructive criticism but theres no need to be an ass about it! Sent from my C6603 using Tapatalk 2 1 Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted June 15, 2013 Share Posted June 15, 2013 ...if you'd read the rest of the thread... I got a .gif for that Quote Link to comment Share on other sites More sharing options...
Dblock Posted June 15, 2013 Share Posted June 15, 2013 Because I already had them from my Beemer and if you'd read the rest of the thread you'd realise that they won't look like that when I'm done with it. There's a saying you know. If you don't have anything nice to say then don't say anything at all. I appreciate opinions and constructive criticism but theres no need to be an ass about it! Sent from my C6603 using Tapatalk 2 It's alright mate look through any post he makes. He just moans about everything. I don't think he has ever made a nice or helpful post. Quote Link to comment Share on other sites More sharing options...
