Jetpilot Posted June 14, 2013 Share Posted June 14, 2013 (edited) What a nasty job, lol I set of this morning to get some 6.5" speakers. I took the original hoping to find a simple spacer to use, no such luck, i perhaps should have searched on here first. So after an hour driving to 3 different shops i followed one of the usa forums and decided to butcher the original speaker with the dremel by cutting the actual magnet and plastic mounts out and use the frame as a spacer. Must have taken 45 mins a side to trim. Then the speaker mounting screw holes were too far out past the spacer so had to redrill the speaker surround with holes closer in, grrrrrrrr! They are in now though and sounding good, a painful job done for what should be a simple task but worth the effort. Amp and sub next Edited June 14, 2013 by Jetpilot Quote Link to comment Share on other sites More sharing options...
MartynB85 Posted June 14, 2013 Share Posted June 14, 2013 I did this too a few weeks ago, mine had some mdf speaker mounts but they were knackered. I butchered the original speakers and used them as mountings, didn't take too long though, jigsaw and a dremel and they fit perfect Did you use the original wiring? I found the hardest part was getting some decent speaker cable through the door plug. My system sounds awesome now though, good speakers, amped with a 10" understrut sub Quote Link to comment Share on other sites More sharing options...
Jetpilot Posted June 14, 2013 Author Share Posted June 14, 2013 Yes buddy, used the original wiring, i have spend days on previous cars doing installs replacing every bit of cabling and just dont think its worth it in the end, unless you have a highly trained ear Quote Link to comment Share on other sites More sharing options...
MartynB85 Posted June 14, 2013 Share Posted June 14, 2013 Yeah i know what you mean, the wiring to the front two speakers was different on mine so i just had to change it all I guess you're powering the front speakers with the original amp then? Any plans on changing the rear speakers? Quote Link to comment Share on other sites More sharing options...
Jetpilot Posted June 14, 2013 Author Share Posted June 14, 2013 Powered from the head unit at present but may upgrade to a small amp at some point, wont use rears, just a sub and amp, think thats more than adequate. Quote Link to comment Share on other sites More sharing options...
MartynB85 Posted June 14, 2013 Share Posted June 14, 2013 Oh ok cool, did you not have the Bose system as standard? Quote Link to comment Share on other sites More sharing options...
glrnet Posted June 14, 2013 Share Posted June 14, 2013 You mean like this, see page 5, only did this a while ago:- http://www.350z-uk.c...-5/page__st__80 **Edit** Now in the Guide section http://www.350z-uk.com/topic/72441-replace-the-front-bose-speakers-with-alpine-65-speakers-spacer/ Quote Link to comment Share on other sites More sharing options...
Jetpilot Posted June 14, 2013 Author Share Posted June 14, 2013 Oh ok cool, did you not have the Bose system as standard? No, just standard stuff so upgraded the head unit too You mean like this, see page 5, only did this a while ago:- http://www.350z-uk.c...-5/page__st__80 **Edit** Now in the Guide section http://www.350z-uk.c...peakers-spacer/ Exactly like that sir Quote Link to comment Share on other sites More sharing options...
glrnet Posted June 14, 2013 Share Posted June 14, 2013 Sorry, feel really guilty now that i didn't do the guide sooner, meant to.................... Quote Link to comment Share on other sites More sharing options...
Jetpilot Posted June 14, 2013 Author Share Posted June 14, 2013 No worries buddy, just stunned that there isnt a spacer available off the shelf for such a popular car, you can seem to get one for just about every other car out there! Never had such a task to swap fronts over before. Quote Link to comment Share on other sites More sharing options...
