M350ZB Posted May 14, 2007 Share Posted May 14, 2007 My 350Z, is still creaking at the rear, seems like rear left, even after i got my axle clicking done, anyone any idea's, only does it when turning left on like say mounting a kerb, or a slant in the land, i notice it when pulling onto dirve, anyone got the same prob, or had it fixed, ? Help me, getting my 350z, immac for the summer meets ? Quote Link to comment Share on other sites More sharing options...
stuey Posted May 14, 2007 Share Posted May 14, 2007 i think ul find its from the front......... the springs moving in the cups....... just needs a little greasin...!! Quote Link to comment Share on other sites More sharing options...
Lincolnbaggie Posted May 15, 2007 Share Posted May 15, 2007 My 350Z, is still creaking at the rear, seems like rear left, even after i got my axle clicking done, anyone any idea's, only does it when turning left on like say mounting a kerb, or a slant in the land, i notice it when pulling onto dirve, anyone got the same prob, or had it fixed, ? Help me, getting my 350z, immac for the summer meets ? Mine was the same; it was the rear anti-roll bar drop link bushes (they dry out). Peel back the rubber boot a little and use spray grease on the joint. Cured mine. Hope that helps. Quote Link to comment Share on other sites More sharing options...
Kuro Posted May 15, 2007 Share Posted May 15, 2007 My 350Z, is still creaking at the rear, seems like rear left, even after i got my axle clicking done, anyone any idea's, only does it when turning left on like say mounting a kerb, or a slant in the land, i notice it when pulling onto dirve, anyone got the same prob, or had it fixed, ? Help me, getting my 350z, immac for the summer meets ? Mine was the same; it was the rear anti-roll bar drop link bushes (they dry out). Peel back the rubber boot a little and use spray grease on the joint. Cured mine. Hope that helps. Hmm, that sounds interesting - any pics? (Mine creaks like an old Spanish Galleon at the rear - usually when reversing over uneven ground. e.g. Up the kerb and onto the driveway.) Quote Link to comment Share on other sites More sharing options...
Lincolnbaggie Posted May 15, 2007 Share Posted May 15, 2007 My 350Z, is still creaking at the rear, seems like rear left, even after i got my axle clicking done, anyone any idea's, only does it when turning left on like say mounting a kerb, or a slant in the land, i notice it when pulling onto dirve, anyone got the same prob, or had it fixed, ? Help me, getting my 350z, immac for the summer meets ? Mine was the same; it was the rear anti-roll bar drop link bushes (they dry out). Peel back the rubber boot a little and use spray grease on the joint. Cured mine. Hope that helps. Hmm, that sounds interesting - any pics? (Mine creaks like an old Spanish Galleon at the rear - usually when reversing over uneven ground. e.g. Up the kerb and onto the driveway.) None from the car, but this is from the Manual. Circled/arrowed bit is the drop link. Try and move the link where it bolts to the anti-roll bar and if it's dry and creaking you'll hear it groaning. Mine made an almighty racket; just a bit of grease around the joint, a few miles to bed it all in and noise has now gone. Quote Link to comment Share on other sites More sharing options...
M350ZB Posted May 15, 2007 Author Share Posted May 15, 2007 Thanks for th pic, im going to give that a go and ill get back to you guys, let you know if it cures it. And yeah mine does it went going over a slant or say half mounting a kerb ? Quote Link to comment Share on other sites More sharing options...
Chris`I Posted May 16, 2007 Share Posted May 16, 2007 Might give this a go on mine, rear is starting to creak a little. I'll get the muppets at the dealership to do it. I'll point and they can grease Quote Link to comment Share on other sites More sharing options...
M350ZB Posted May 23, 2007 Author Share Posted May 23, 2007 been so busy of late, not even had a chance to look at it, hopefully will tommorow, anyone ever cured there 350z, how the dealers go ? Quote Link to comment Share on other sites More sharing options...
Chris`I Posted May 23, 2007 Share Posted May 23, 2007 Hopefully going into the dealers tonight as I have developed a rattling from under the steering column as well. Should be a quick fix for both I'm hoping. Quote Link to comment Share on other sites More sharing options...
