Eddieo Posted June 13, 2013 Share Posted June 13, 2013 Anyone had this? I have had anti-roll bar link changed and U-Shaped wishbone with ball joint and its still doing it help!!!!! Does not do it on mormal oads when driving! Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted June 13, 2013 Share Posted June 13, 2013 (edited) More than likely it will be the compression rod ball joint or the compression rod bushing. Â The bushing is easy to check however the ball joint is a bit more trickier. Â Both in stock and good to go same/next day. Â Just drop me a PM if I can help further mate. Â Alex. Edited June 13, 2013 by ZMANALEX 1 Quote Link to comment Share on other sites More sharing options...
Dan2013 Posted June 26, 2013 Share Posted June 26, 2013 Eddio, I'm having the exact same problem on my Z. Whenever i go over rough roads/potholes it makes like a knocking/thudding sound.. gets very annoying! Quote Link to comment Share on other sites More sharing options...
JackStrong Posted June 26, 2013 Share Posted June 26, 2013 This on the passenger front or rear ? Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted June 26, 2013 Share Posted June 26, 2013 Also check if the front forward section of the wheel arch liner is attached to the undertray 1 Quote Link to comment Share on other sites More sharing options...
Eddieo Posted June 27, 2013 Author Share Posted June 27, 2013 passenger front, but i think the grill might be lose as i have had it check and they said there is nothing wrong with it. i have a cobra grill fitted amd it is lose . been told check the bumper is not lose Quote Link to comment Share on other sites More sharing options...
Eddieo Posted June 27, 2013 Author Share Posted June 27, 2013 dan check there is nothing lose mate on the bumper! Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted June 27, 2013 Share Posted June 27, 2013 BANANABAR 1 Quote Link to comment Share on other sites More sharing options...
Eddieo Posted June 27, 2013 Author Share Posted June 27, 2013 Had them checked bananabar all ok on mine! Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted June 28, 2013 Share Posted June 28, 2013 Had them checked bananabar all ok on mine! Â Worn out Banana Bar Ball Joint is notoriously difficult to diagnose whilst on the car and almost as difficult when BB is removed. Does the knocking disappear when left foot braking over the rough ground whilst maintaining forward motion ? Â It's usually the passenger side that goes first as well. I'm afraid your symptoms are classic BBBJ failure ... Quote Link to comment Share on other sites More sharing options...
Eddieo Posted June 28, 2013 Author Share Posted June 28, 2013 it is the passenger side thats doing it!! just bumps it does it when on normal roads its fine! i might get it changed then thanks Quote Link to comment Share on other sites More sharing options...
Eddieo Posted June 28, 2013 Author Share Posted June 28, 2013 attak z so i would need front passenger lower wishbone arm? Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted June 28, 2013 Share Posted June 28, 2013 attak z so i would need front passenger lower wishbone arm? Not wishbone but compression rod ... PM ZedmanAlex, he posted above Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted June 28, 2013 Share Posted June 28, 2013 Please let us know how you get on for future reference Quote Link to comment Share on other sites More sharing options...
Eddieo Posted June 28, 2013 Author Share Posted June 28, 2013 cheers Quote Link to comment Share on other sites More sharing options...
benjy88 Posted July 14, 2013 Share Posted July 14, 2013 Absolutely 100% agree with ATTAK Z, just had mine changed... same thing, slight knocking on passenger side... which developed into more of a 'cannon-fire' type sound eventually... had it changed. Noise went. Simples, got one for £80, and problem solved.  It's the ole bananabar. 1 Quote Link to comment Share on other sites More sharing options...
flyboy Posted July 15, 2013 Share Posted July 15, 2013 (edited) Just had my bushes in the Bannana bar and also the drop links changed today  Problem gone away and it turns in like it used to Edited July 16, 2013 by flyboy Quote Link to comment Share on other sites More sharing options...
