KyleR Posted June 13, 2013 Share Posted June 13, 2013 Have some LED rears that are surplus to requirements. They're not the nissan OEM that you can get from a facelift car or Alex, but they are the OEM style ones that you can get on eBay for about £165. They've been on the car since Feb and have zero marks/chips/wear, however, not being OEM they're not just as perfect a fit. Once they're on they're a perfect fit, but the screw holes take a little fiddling with a round file which was a 2 minute job when I fitted them, but you may want to give them a further little touch to make fitting easier for you. The only other negative point about them in the fitting of the screw caps, the clip holes aren't really usable so if you wish to use your OEM caps you'll have to snip off the little tabs and glue them on. They look good, they work good, and they take no more messing about to fit that OEM LED's which need you to file down the guides on the cars loom to fit into the lamp, these however are truly a straight swap, just plug in the loom form your pre facelift and they'll work from the off Piccies time, hope they work as I heard photobucket has changed a few things recently... £120 delivered using Royal Mail Special Delivery Quote Link to comment Share on other sites More sharing options...
KyleR Posted June 14, 2013 Author Share Posted June 14, 2013 Couple of pics on the car Quote Link to comment Share on other sites More sharing options...
MWTech Posted June 14, 2013 Share Posted June 14, 2013 PM coming 1 Quote Link to comment Share on other sites More sharing options...
KyleR Posted June 15, 2013 Author Share Posted June 15, 2013 Sold Quote Link to comment Share on other sites More sharing options...
ironhide Posted June 20, 2013 Share Posted June 20, 2013 Is there any difference between the OEM Nissan ones and the eBay ones? Quote Link to comment Share on other sites More sharing options...
