MrRoper Posted June 13, 2013 Share Posted June 13, 2013 Hi Everyone, I seem to have a small water leak somehwere, after a heavy rain spell, I get a 5-6 water drops from the underneath of the drivers side dashboard onto my legs, after feeling underneath the dash, I can feel a little water collected and the metal bracket near to the bonnet release is slightly rusted suggesting its been there for a while. This only happens when its rained so its not the aircon, Is this likely to be the windshield seal or are there any other areas that might be letting in water? Regards Quote Link to comment Share on other sites More sharing options...
Renegade Posted June 13, 2013 Share Posted June 13, 2013 There is a drain hole near the drivers side wiper blade, it gets blocked easy. Lift the brake fluid cover too, you can see that the water just runs down the bulkhead on the outside. 1 Quote Link to comment Share on other sites More sharing options...
Ebized Posted June 13, 2013 Share Posted June 13, 2013 There is a drain hole near the drivers side wiper blade, it gets blocked easy. Lift the brake fluid cover too, you can see that the water just runs down the bulkhead on the outside. Good advice Use a pressure washer or strong hose jet on the drain holes until you see the gathered water flowing easily away. It may be the windscreen seal if not, but blocked drain holes have been known to allow water build-up to seep into the footwell areas through grommets etc. Quote Link to comment Share on other sites More sharing options...
MrRoper Posted June 13, 2013 Author Share Posted June 13, 2013 There is a drain hole near the drivers side wiper blade, it gets blocked easy. Lift the brake fluid cover too, you can see that the water just runs down the bulkhead on the outside. Cheers guys, Do you know where the drain hole is in relation to the wiper? under the wiper drive shaft? Many thanks Quote Link to comment Share on other sites More sharing options...
Renegade Posted June 13, 2013 Share Posted June 13, 2013 Just look where the arm is fixed to the spindle, the little hole is at the front, unless its full of junk . Lifting the brake pot cover, you might see if there is any water build up. Quote Link to comment Share on other sites More sharing options...
MrRoper Posted June 14, 2013 Author Share Posted June 14, 2013 (edited) So the drains look clear however There is some kind of bulkhead seal near the ABS Actuator which seems to get a huge amount of rain poured onto it. That will be my first suspect when I get the plastic cowl off etc this weekend! Its going to be a nightmare to reproduce, even after 5 hours of heavy rain the interior is dry! Edited June 14, 2013 by MrRoper Quote Link to comment Share on other sites More sharing options...
MrRoper Posted July 2, 2013 Author Share Posted July 2, 2013 Hi guys, I have had another look into this after getting my legs wet again today! The leak is high up underneath the dash somewhere, looking up from the footwell you can see a large metal cylindrical supporting pillar that looks to support the top of the steering column etc. The leak is coming from above this beam/pillar as there is slight rust on this beam and also kitchen roll is slightly damp after a downpour. is the only thing above this the window seal? or is there anywhere else anyone can think of that is a possible cause? Cheers in advance! Quote Link to comment Share on other sites More sharing options...
KyleR Posted July 2, 2013 Share Posted July 2, 2013 (edited) Under the brake fluid cover there may be a hole or 2... Oops already suggested Edited July 2, 2013 by KyleR Quote Link to comment Share on other sites More sharing options...
MrRoper Posted July 10, 2013 Author Share Posted July 10, 2013 Just an update, it's the window bonding, the glass hasn't been primed properly at some point so was loose, unfortunately this has caused some rust at the top of the window frame, so my car is sat outside the house with no windscreen all the rust has been removed and treated though and ready for some primer! Window guy is back tomorrow morning to refit! Quote Link to comment Share on other sites More sharing options...
Cal Posted February 3, 2014 Share Posted February 3, 2014 I'm getting the same thing, but passenger side... Went to a hand car wash yesterday and literally saw it dripping when the guy pressure washed the passenger bonnet/wing area. Any ideas? Quote Link to comment Share on other sites More sharing options...
Dashurik Posted February 3, 2014 Share Posted February 3, 2014 I had the same problem.Most likely you have a leak from where the rubber gourmet sits in the body(place where all your cables from engine,battery runs inside the cabin).Its probably loose or completely off the position(did you have custom stereo installed,that's why mine was loose?).You will need to remove battery cover and it's surround,half of glass trim and then you will be able to get access to gourmet. I used water proof tape to tape around it.Never had problems since then.Also most likely you drainage points are blocked too(crap from trees and dirt).Hope that will help. 1 Quote Link to comment Share on other sites More sharing options...
Cal Posted February 3, 2014 Share Posted February 3, 2014 I had the same problem.Most likely you have a leak from where the rubber gourmet sits in the body(place where all your cables from engine,battery runs inside the cabin).Its probably loose or completely off the position(did you have custom stereo installed,that's why mine was loose?).You will need to remove battery cover and it's surround,half of glass trim and then you will be able to get access to gourmet. I used water proof tape to tape around it.Never had problems since then.Also most likely you drainage points are blocked too(crap from trees and dirt).Hope that will help. Thanks mate, I'll get those checked! Quote Link to comment Share on other sites More sharing options...
