S1an1de Posted June 9, 2013 Share Posted June 9, 2013 Ok heres the story... I'm getting a "squeal" from the rear passenger side under heavy acceleration and what appears to be a pronounced "judder" from the same wheel under hard braking at speed. I've already changed the Pads, bedded them in, greased shims etc but am now at the end of my mechanical knowledge to be able to diagnose the problem. I don't want to fork out for new parts until i'm fairly confident what the problem is. Is there anyone in the Sheffield area [specifically near Meadow Hall] thats a bit mechanically minded that wouldnt mind a quick PAX ride out and diagnose later today [sunday]? Ta in advance Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted June 9, 2013 Share Posted June 9, 2013 Have you checked for excess movement of the rear hub? All hub parts including bushes, arms and bearings are in stock and good to go same/next day if required. Good luck with your diagnoses. Alex. Quote Link to comment Share on other sites More sharing options...
