modd1uk Posted June 7, 2013 Share Posted June 7, 2013 Wednesday night the EML came on when i started the engine, i knew all levels were fine as i checked them prior to setting off. Had the code read today and it came back with P0174 Fuel System Lean, Bank 2, Cleared the code and took the car for a good spin and carried on as normal and its fine now, the light hasn't come back on.Even when the light was on the car was perfectly normal, no hesitation no stuttering etc. Any idea what it could be/what i can do to help ? 06 Revup with 53k on the clock. Quote Link to comment Share on other sites More sharing options...
MrRoper Posted June 7, 2013 Share Posted June 7, 2013 Found you this http://www.350z-uk.com/topic/45435-engine-warning-light-p0171-fuel-system-lean-help/ I would check the air filter is clean, check the MAF sensor wiring and then reset the code and cross your fingers it was a 'glitch'! Quote Link to comment Share on other sites More sharing options...
modd1uk Posted June 8, 2013 Author Share Posted June 8, 2013 No light has come on back yet, hopefully it was just a glitch. Gonna do the above though. Quote Link to comment Share on other sites More sharing options...
