smudgedon Posted June 5, 2013 Share Posted June 5, 2013 So it turns out that tbe face lift a/c controls don't work on a DE engined car.... So how and why do people upgrade the interior? Does anyone know a way around this? Quote Link to comment Share on other sites More sharing options...
SteveM Posted June 5, 2013 Share Posted June 5, 2013 you need to change the AC control unit Quote Link to comment Share on other sites More sharing options...
The Bounty Bar Kid Posted June 5, 2013 Share Posted June 5, 2013 Didn't know anybody had done this before. Was looking forward to seeing how you were gonna do this. Quote Link to comment Share on other sites More sharing options...
MartynB85 Posted June 5, 2013 Share Posted June 5, 2013 you need to change the AC control unit Is that just the white box behind the contols? Quote Link to comment Share on other sites More sharing options...
SteveM Posted June 5, 2013 Share Posted June 5, 2013 you have to make sure that the AC control unit is matched to the AC controls as they are not interchangable..... there are several part numbers for the same parts Quote Link to comment Share on other sites More sharing options...
SteveM Posted June 5, 2013 Share Posted June 5, 2013 you need to change the AC control unit Is that just the white box behind the contols? yep Quote Link to comment Share on other sites More sharing options...
SteveM Posted June 5, 2013 Share Posted June 5, 2013 same part different number and so didnt work Quote Link to comment Share on other sites More sharing options...
smudgedon Posted June 5, 2013 Author Share Posted June 5, 2013 So you use the hr a/c control box with the existing DE wiring in the car? Quote Link to comment Share on other sites More sharing options...
Mark@Abbey m/s Posted June 5, 2013 Share Posted June 5, 2013 Will need to dig this out Jordan and try again next week. Quote Link to comment Share on other sites More sharing options...
SteveM Posted June 5, 2013 Share Posted June 5, 2013 So you use the hr a/c control box with the existing DE wiring in the car? i believe so.... its the fact that the older control box is trying to talk to a newer control panel. the wiring into the unit isnt much different but the electronics in the switchgear is.... Quote Link to comment Share on other sites More sharing options...
SteveM Posted June 5, 2013 Share Posted June 5, 2013 i had a AC control unit fail on mine.. got a replacement but it tunrned out to be from a DE car. it ran the system but was all over the place with the controls not turning the right thing on and the dials not working correctly. swapped it out for a unit from a newer car with the same part numbers as the original and presto.. works great Quote Link to comment Share on other sites More sharing options...
smudgedon Posted June 5, 2013 Author Share Posted June 5, 2013 Will need to dig this out Jordan and try again next week. So were you trying to link the face lift a/c control to the DE a/c module (the white box)? Quote Link to comment Share on other sites More sharing options...
