Report: Scholl S17+ Paint Correction
Dave-350
Hi guys,
I cant be assed to go in to massive detail about this but I thought I would give you all a few words about some products.
Car: 350z Gunmetal Grey
Compounds: Scholl S17+
Pads: Lake Country Constant Pressure
Polisher: DAS6 DA
Clay: Bilt Hamber
Others: Usual Iron X, Tardis, Born-Slippy Lube, mint rims...
Anyway, firstly if you are using any other clay bar other than the Bilt Hamber clay you need to sort yourself out - Seriously, this clay is the best I have ever used and you get mucho bang-for-your-buck. It can also be used with water or lube.
Anyway, wash the car by hand using a mixture of shampoos.
cleaned the wheels with Minty Rims cleaner.
Snow Foam mix with Megs new shampoo.
Clayed using BH clay and born Slippy lube.
Then LC:CP pads with scholl S17+...
12 hours later - Swirl free paint.
Good work :)
Looks like Scholl S17+ is has a heavy cut. How have you refined it?
I wouldn't say its a heavy cut - More of an in-between/medium cut. But it depends on how much you work it.
With a DA you need to make sure you get it up to speed (Speed 6 on the DAS6) then work down making around 8 - 10 passes. This will give you quite a light cut but also enough so you don't get any marring/hazing.
It was quite a hot day when I did this, so when it's colder you would probably need to work it a bit more to make sure the compound is completely broken down.
I would recommend it anyway, but would work better with a Rotary.
