spleenboy Posted June 2, 2013 Share Posted June 2, 2013 Need help people I'm aware that jet motors fail all too often but both my front and rear have stopped at the same time which leads me to think it may be electrical rather than mechanical failure. I cannot hear any motor activity at all which rules out valves and blockages. Was advised the fuse was by the battery but cannot see a lable for washers. Can anyone tell me which one it is if it is in this cluster or if not where I can find it as I also checked the under dash bank as well? Many thanks Matt Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted June 2, 2013 Share Posted June 2, 2013 Matt, It is in the IPDM at the battery. It is the 4th one down on the right and rated at 10 amps. Alex. Quote Link to comment Share on other sites More sharing options...
Ebized Posted June 3, 2013 Share Posted June 3, 2013 Matt, It is in the IPDM at the battery. It is the 4th one down on the right and rated at 10 amps. Alex. There you go - your first post and expert advice before you have even introduced yourself, so one good turn............ Quote Link to comment Share on other sites More sharing options...
cs2000 Posted June 3, 2013 Share Posted June 3, 2013 (edited) Yep, OMG what a stupid place for a fuse box too... Its not hard to get too, per-se, but you just cant do it in a hurry, like the fusebox in the footwell or something... Battery compartment lid off, Plastic surround out (5 popper style clips), Windscreen trim finisher out (1 popper style clip) and then pull towards front of car to release clips). You will then see it behind the battery to the right. Edited June 3, 2013 by cs2000 Quote Link to comment Share on other sites More sharing options...
spleenboy Posted June 3, 2013 Author Share Posted June 3, 2013 Ahhh that makes more sense as I could only see another fuse holder in front of the battery that did not show the washers. Will tkae off the surround and get checking. Thanks Gents - I really appreciate the help and am pleased a forum like this exists for newbies like me. Am loving my 350 and am so pleased I bought it Matt Quote Link to comment Share on other sites More sharing options...
cs2000 Posted June 3, 2013 Share Posted June 3, 2013 Glad you're enjoying it ! I wanted to check the headlamp washer fuse too a month orso ago and was left stumped until I found this! No idea what's wrong with 1 fuse box, what necessitated 3! 1 Quote Link to comment Share on other sites More sharing options...
starlet95 Posted March 24, 2019 Share Posted March 24, 2019 Hi guys im having the same problem with mine. But to top it off I’ve checked all fuses and I’ve even replaced them just incase. Yet no joy with both front and rear washers still not working Any help would be appreciated thanks Quote Link to comment Share on other sites More sharing options...
OnlyAfro Posted March 24, 2019 Share Posted March 24, 2019 9 minutes ago, starlet95 said: Hi guys im having the same problem with mine. But to top it off I’ve checked all fuses and I’ve even replaced them just incase. Yet no joy with both front and rear washers still not working Any help would be appreciated thanks Multimeter on the contacts? Just replace the pumps if that's successful. Quote Link to comment Share on other sites More sharing options...
