Vanity Light LED Upgrade
BulletMagnet
Decided to do something about this
So I went and ordered these off eBay
http://bit.ly/11JXhOe
First I took the sun visor off it's mounting point and disconnected the power cable.
Then carefully remove the light diffuser, pay close attention to the two tabs near the bulb as they can snap with too much force, also be careful with the mirror glass as it is not very thick.
Then you should see this
Replace candescent bulb with LED item
Plug the wire in to test you put the LED bulb in the correct way
When refitting the light diffuser take care again with the two tabs.
I found it easier to work it in from one side to the other.
And all back together
Hope this helps anybody who is looking to do this
  • Like 3
UPDATE
Have since found out that the JDM models have a bulb soldered in rather than a bulb fitting.
Reason I know was cos I broke drivers mirror, saw a visor on eBay, bought it, received today, opened it up, went "MEH!" upon seeing soldered bulb, went to extract mirror glass, went to put mirror glass into my visor, cracked that, went "MEH!" again, went to Nissan to ask if they sold the mirror glass after looking in local motor factors, was told I would have to buy whole sun visor, asked how much, they didn't want to say, asked them again how much, they said £200 + VAT, went "MEH!!!" inside my head, thanked them and walked out, went to a local glass & mirror maker to see if they had off cuts, they did, cut me a piece for £3, was happy and went home, fitted new mirror glass and pointed LEDs upward by 45 degrees, less glare now much better, reassembled everything and job done :)
Edited by BulletMagnet
  • 7 months later...
Good info, did this today, exactly the same on the 370z
I used a very small screwdriver between the hinge and glass frame (small gap on the side) to lever the light cover off, this way you are nowhere near that thin mirror glass
Edited by GIXXERUK
  • 5 months later...
  • 2 months later...
  • 9 months later...
  • 1 month later...
UPDATE
Is the specific to JDM? Mine is defo not a JDM (HPI, Chassis, & VIN confirmed) yet today I went to perform this Mod and found I too have soldered in bulb??
  • 3 months later...
Just Bought this kit from Ebay for all the interior + number plate lights.
http://www.ebay.co.uk/itm/400844199521
Any idea if these will fit the 370z ?
Thanks in advance
Honestly not sure, interior lights are pretty standard across all vehicles as far as I know / see, so I don't see why not. Maybe post link in the 370z forum and ask someone?
Thanks in advance
ok thanks
  • 4 weeks later...
Reason I know was cos I broke drivers mirror, saw a visor on eBay, bought it, received today, opened it up, went "MEH!" upon seeing soldered bulb, went to extract mirror glass, went to put mirror glass into my visor, cracked that, went "MEH!" again, went to Nissan to ask if they sold the mirror glass after looking in local motor factors, was told I would have to buy whole sun visor, asked how much, they didn't want to say, asked them again how much, they said £200 + VAT, went "MEH!!!" inside my head, thanked them and walked out, :scare::)
MEH!!! LMAO.. Gotta love Nissan OEM prices..
Nice guide, Thanks.
Hope your not superstitious.
Nice guide, Thanks.
Well, it was 2013 when it happened, have since moved within an hours drive from the Nürburgring, so I think I'm good, thanks tho :lol:
