adevine Posted May 31, 2013 Share Posted May 31, 2013 Hello Everyone, Wondering if you can help, Recently fitted an Gemini Invidia Exhaust with Invidia HFC's to my 370z (Thanks Tarmac Sportz). However after 30 miles or so my engine light has since come on adn i was wondering if anyone has had the same issue? I was kind of ecpecting it to come on then to go off but this has not happened and im now into about 500 miles with the new exhaust. Any ideas????? I have been told it could be the O2 sensors? Spacers may solve the issue. However i wanted other peoples opinion. Any help would be greatly appreciated. P.S why does it take so long to upload a pic on here?????? Quote Link to comment Share on other sites More sharing options...
M13KYF Posted May 31, 2013 Share Posted May 31, 2013 I thought spacers are only required when decatting Have you tried an ECU reset no problems with loading pictures, more likely operator error Most of us use Photobucket, makes it even easier. There is a guide in Forum Help if you havent used it before and its also free to use. Quote Link to comment Share on other sites More sharing options...
adevine Posted May 31, 2013 Author Share Posted May 31, 2013 I thought spacers are only required when decatting Have you tried an ECU reset no problems with loading pictures, more likely operator error Most of us use Photobucket, makes it even easier. There is a guide in Forum Help if you havent used it before and its also free to use. No ECU reset as yet, i wanted to get some ideas as to what it may be. Will probably end up taking it to Nissan and get a remap?? Ill use photo bucket me thinks, thanks! Quote Link to comment Share on other sites More sharing options...
SteveM Posted May 31, 2013 Share Posted May 31, 2013 Will probably end up taking it to Nissan and get a remap?? forget taking it to Nissan for this... take it to someone who knows what they are doing instead! Abbey Motorsport or Horsham developments both of which are traders on here Quote Link to comment Share on other sites More sharing options...
M13KYF Posted May 31, 2013 Share Posted May 31, 2013 +1 also TDI North never heard that Nissan can do remaps. Quote Link to comment Share on other sites More sharing options...
Will370z Posted May 31, 2013 Share Posted May 31, 2013 Yup it will be the hfc's Quote Link to comment Share on other sites More sharing options...
adevine Posted May 31, 2013 Author Share Posted May 31, 2013 Will probably end up taking it to Nissan and get a remap?? forget taking it to Nissan for this... take it to someone who knows what they are doing instead! Abbey Motorsport or Horsham developments both of which are traders on here Just had a look and its a bit of a treck for me, Might be the only option though, Thanks. Quote Link to comment Share on other sites More sharing options...
Mark@Abbey m/s Posted June 1, 2013 Share Posted June 1, 2013 whats the code thats causing the CEL If your handy with a computer I can sort this remote once I send you a Uprev cable to borrow. Quote Link to comment Share on other sites More sharing options...
adevine Posted June 3, 2013 Author Share Posted June 3, 2013 whats the code thats causing the CEL If your handy with a computer I can sort this remote once I send you a Uprev cable to borrow. Mark, Im not sure of the code, im currently working in Norway at the moment, Ill get the code when im home in a week and ill contact you. Thanks for your help. Quote Link to comment Share on other sites More sharing options...
Steel Lynx Posted April 24, 2014 Share Posted April 24, 2014 Just out of interest how do you do a manual reset on a 370? And does it wipe an UpRev and literally reset it back to stock? (assuming the old information is even still kicking around in there) Quote Link to comment Share on other sites More sharing options...
370Ad Posted April 24, 2014 Share Posted April 24, 2014 Pedal dance or remove negative battery terminal. UpRev will stay until you remove it with software so don't worry about that! Quote Link to comment Share on other sites More sharing options...
370Ad Posted April 24, 2014 Share Posted April 24, 2014 Pedal Dance: 1) With the key in your pocket/car, push the Engine Start button TWICE (so the car is fully on, but not started) 2) Within three seconds of the car "ON" (again NOT started), Floor (all the way down) and Release the gas pedal fully 5 times within 5 seconds. Do not do this too fast.. 1..2..3..4..5 3) Wait 7 seconds then floor the gas pedal and hold for 10 seconds. After that 10 seconds the Check Engine Light will start to blink slowly. 4) Release the pedal and floor it down once again and hold for 10 seconds. After these 10 seconds the check engine light will disappear then Quote Link to comment Share on other sites More sharing options...
Justthejedi Posted April 24, 2014 Share Posted April 24, 2014 Hello Everyone, Wondering if you can help, Recently fitted an Gemini Invidia Exhaust with Invidia HFC's to my 370z (Thanks Tarmac Sportz). However after 30 miles or so my engine light has since come on adn i was wondering if anyone has had the same issue? I was kind of ecpecting it to come on then to go off but this has not happened and im now into about 500 miles with the new exhaust. Any ideas????? I have been told it could be the O2 sensors? Spacers may solve the issue. However i wanted other peoples opinion. Any help would be greatly appreciated. P.S why does it take so long to upload a pic on here?????? Will be oxygen sensor, had exactly the same thing happen on mine when I had my cobra exhaust fitted, only my engine light came on about 5 mins down the road, done a quick u-turn back to the garage, plugged in the laptop, sure enough, oxygen sensor fault, got it re-set, light out, been ok ever since. Quote Link to comment Share on other sites More sharing options...
GMballistic Posted April 24, 2014 Share Posted April 24, 2014 Hello Everyone, Wondering if you can help, Recently fitted an Gemini Invidia Exhaust with Invidia HFC's to my 370z (Thanks Tarmac Sportz). However after 30 miles or so my engine light has since come on adn i was wondering if anyone has had the same issue? I was kind of ecpecting it to come on then to go off but this has not happened and im now into about 500 miles with the new exhaust. Any ideas????? I have been told it could be the O2 sensors? Spacers may solve the issue. However i wanted other peoples opinion. Any help would be greatly appreciated. P.S why does it take so long to upload a pic on here?????? Will be oxygen sensor, had exactly the same thing happen on mine when I had my cobra exhaust fitted, only my engine light came on about 5 mins down the road, done a quick u-turn back to the garage, plugged in the laptop, sure enough, oxygen sensor fault, got it re-set, light out, been ok ever since. Just fyi ~ that post you quoted was from May 2013 so I think he'll have got it sorted by now. Or possibly have sold the car. 1 Quote Link to comment Share on other sites More sharing options...
Steel Lynx Posted April 24, 2014 Share Posted April 24, 2014 Pedal Dance: 1) With the key in your pocket/car, push the Engine Start button TWICE (so the car is fully on, but not started) 2) Within three seconds of the car "ON" (again NOT started), Floor (all the way down) and Release the gas pedal fully 5 times within 5 seconds. Do not do this too fast.. 1..2..3..4..5 3) Wait 7 seconds then floor the gas pedal and hold for 10 seconds. After that 10 seconds the Check Engine Light will start to blink slowly. 4) Release the pedal and floor it down once again and hold for 10 seconds. After these 10 seconds the check engine light will disappear then Thank you for that Quote Link to comment Share on other sites More sharing options...
Justthejedi Posted April 24, 2014 Share Posted April 24, 2014 Hello Everyone, Wondering if you can help, Recently fitted an Gemini Invidia Exhaust with Invidia HFC's to my 370z (Thanks Tarmac Sportz). However after 30 miles or so my engine light has since come on adn i was wondering if anyone has had the same issue? I was kind of ecpecting it to come on then to go off but this has not happened and im now into about 500 miles with the new exhaust. Any ideas????? I have been told it could be the O2 sensors? Spacers may solve the issue. However i wanted other peoples opinion. Any help would be greatly appreciated. P.S why does it take so long to upload a pic on here?????? Will be oxygen sensor, had exactly the same thing happen on mine when I had my cobra exhaust fitted, only my engine light came on about 5 mins down the road, done a quick u-turn back to the garage, plugged in the laptop, sure enough, oxygen sensor fault, got it re-set, light out, been ok ever since. Just fyi ~ that post you quoted was from May 2013 so I think he'll have got it sorted by now. Or possibly have sold the car. oh yeah....oops, my bad. Quote Link to comment Share on other sites More sharing options...
GMballistic Posted April 24, 2014 Share Posted April 24, 2014 Hello Everyone, Wondering if you can help, Recently fitted an Gemini Invidia Exhaust with Invidia HFC's to my 370z (Thanks Tarmac Sportz). However after 30 miles or so my engine light has since come on adn i was wondering if anyone has had the same issue? I was kind of ecpecting it to come on then to go off but this has not happened and im now into about 500 miles with the new exhaust. Any ideas????? I have been told it could be the O2 sensors? Spacers may solve the issue. However i wanted other peoples opinion. Any help would be greatly appreciated. P.S why does it take so long to upload a pic on here?????? Will be oxygen sensor, had exactly the same thing happen on mine when I had my cobra exhaust fitted, only my engine light came on about 5 mins down the road, done a quick u-turn back to the garage, plugged in the laptop, sure enough, oxygen sensor fault, got it re-set, light out, been ok ever since. Just fyi ~ that post you quoted was from May 2013 so I think he'll have got it sorted by now. Or possibly have sold the car. oh yeah....oops, my bad. Still, your post might help someone else out. Quote Link to comment Share on other sites More sharing options...
