Bose to Alpine amp help
Patch
You'll need to remove the centre console plastics from top to bottom. Fairly straight forward, just remember to unplug the wire going to the triple gauges ;)
Open top cubby, remove the rubber mat at the front, revealing screws, remove screws, lift plate, remove more screws.
Then pull and lift the bottom lip of the gear lever surround, be careful, but firm, it's only held in by clips.
Once gear lever surround is off, you will be able to see the screws holding the bottom part of the centre console plastic.
It also helps if you unscrew the white AC control box, just don't forget to plug the white flatband cable back in on reassembly.
