P3 Service?
AMT
Ok, so my cars went P1, P2, P1 then Lotus had a jap specialist across the road give it a minor service when I bought it and put down P1, so even though its a bit out its gettin' a P3 at Infiniti Glasgow on Thursday.
What should I be expecting, I've looked at various sites and some specialist have different things..which is helpful so;
Oil change
Oil filter
x2 air filters
brake fluid change(?)
Some have said the diff oil but its only got 27200miles so then they said prob won't need that.
anything missing or don't need?
Thanks for the help!
I'm doubting spark plugs need replaced at 27200miles? and the LSD oil?... also whats a PCV filter and does tht apply to the Zed? lol
Edited by AMT
Positive crankcase ventilation
Car manufacturers suggest that PCV valves be cleaned or replaced after somewhere between 20,000 to 50,000 miles of driving. Consult your owner’s manual to see where the PCV valve is located on your vehicle and what the recommended service intervals are.
Edited by Yampiedog
As you can see from the service sheet, on the 350z the P2 and P3 are the same.
The sheet states that with our LSD the oil is only inspected and not changed.
Additional items at customers extra expense include....
Brake fluid change every 2 yrs
Coolant change every 3 yrs
New spark plugs every 5 yrs
Just had my P2 at 8 yrs old including brake fluid change for just under £160 supplying my own oil at Lockwood and Greenwood independent in Manchester.
They service a lot of the member's zed's in the North West and give a club discount too :thumbs:
