Carl350z Posted May 25, 2013 Share Posted May 25, 2013 Hi everyone, I think I have a possible major issue with my new car ! When being driven hard! Change from 3rd to 4th is horrible it either crunches in or you have hold the clutch for .5secs before hitting forth. Anybody experienced this? Thanks Quote Link to comment Share on other sites More sharing options...
Gonzo88 Posted May 25, 2013 Share Posted May 25, 2013 Get the synchro checked... Is it definitely the gearbox? Not the clutch slipping? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 25, 2013 Share Posted May 25, 2013 I take it that is half a second and not 5 seconds? Depending on the age and mileage of your car then half is second is not unusual. Just drive with a bit more mechanical sympathy and adjust your driving style to compensate for the gearbox wear so that it does not crunch between shifts. Alex. Quote Link to comment Share on other sites More sharing options...
KyleR Posted May 25, 2013 Share Posted May 25, 2013 Quite common, mine does it from time to time into 6th. It's the synchromesh and it needs replaced, £500 upwards Quote Link to comment Share on other sites More sharing options...
The Chubby Ninja Posted May 25, 2013 Share Posted May 25, 2013 Quite common, mine does it from time to time into 6th. It's the synchromesh and it needs replaced, £500 upwards do you know how much a second hand gearbox is for comparison? Quote Link to comment Share on other sites More sharing options...
cs2000 Posted May 25, 2013 Share Posted May 25, 2013 500-750 depending on age of the replacement box. Mine does the same into 6th Quote Link to comment Share on other sites More sharing options...
The Chubby Ninja Posted May 25, 2013 Share Posted May 25, 2013 alright cool, the OP might aswell change the gearbox but its not to say the new one will do the same 6 months down the line Quote Link to comment Share on other sites More sharing options...
marzman Posted May 25, 2013 Share Posted May 25, 2013 An awful lot of zeds suffer from crunching gears (mine included). 1. Replace the gearbox oil and add Molyslip. (PM ZMANALEX for the correct fluids). 2. Double clutch gear change on the affected gears. i.e. on my car from 2nd to third, i press the clutch, change from 2nd to neutral, release the clutch and press it again, and change into third. You get used to it in no time (and from habit i now do it when driving other cars too!) Quote Link to comment Share on other sites More sharing options...
hawker1986 Posted May 25, 2013 Share Posted May 25, 2013 Ours started doing this going into 5th the other day, its going in to pay a visit with Andy and Mitz Tuesday , hoping its not going to cost the whole earth. Hawker Quote Link to comment Share on other sites More sharing options...
