fastbike52 Posted May 24, 2013 Share Posted May 24, 2013 my 54 plate 350z has just failed the MOT due to brake lines excessivly corroded , had the garage replace the bad pipes but on returning home with the mot pass doc in the advisory section of the mot there are several more brake pipes required tob e replaced in the future , my question is can anyone tell me ( without me crawling around under the car ) are these pipes able to be replaced with standard copper brake pipes ???? and what diameter is the pipe required Quote Link to comment Share on other sites More sharing options...
taras Posted May 24, 2013 Share Posted May 24, 2013 To make it easier, why not just buy mine? http://www.ebay.co.uk/itm/NISSAN-350Z-Z33-REAR-brake-lines-pipes-ORIGINAL-parts-both-LEFT-and-RIGHT-/251265731002?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a809ac9ba Brand new never fitted. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 24, 2013 Share Posted May 24, 2013 The standard Kunifer copper 3/16" pipe is what you require. Alex. Quote Link to comment Share on other sites More sharing options...
fastbike52 Posted May 25, 2013 Author Share Posted May 25, 2013 The standard Kunifer copper 3/16" pipe is what you require. Alex. thanks alex can get thhat through my work cheers Quote Link to comment Share on other sites More sharing options...
The Chubby Ninja Posted May 25, 2013 Share Posted May 25, 2013 my 54 plate 350z has just failed the MOT due to brake lines excessivly corroded , had the garage replace the bad pipes but on returning home with the mot pass doc in the advisory section of the mot there are several more brake pipes required tob e replaced in the future , my question is can anyone tell me ( without me crawling around under the car ) are these pipes able to be replaced with standard copper brake pipes ???? and what diameter is the pipe required are you from central Scotland by any chance? just I was talking to a mechanic in alloa yesterday and he said he had just done the brake pipes on a 350z Quote Link to comment Share on other sites More sharing options...
The Chubby Ninja Posted May 25, 2013 Share Posted May 25, 2013 infact just seen your welcome post. Finally another zed in my area . you should put your name down on the Scottish zeds list http://www.350z-uk.com/topic/30530-scottish-zeds/ . I`ll keep an eye out for you as im just outside alloa Quote Link to comment Share on other sites More sharing options...
fastbike52 Posted May 27, 2013 Author Share Posted May 27, 2013 my 54 plate 350z has just failed the MOT due to brake lines excessivly corroded , had the garage replace the bad pipes but on returning home with the mot pass doc in the advisory section of the mot there are several more brake pipes required tob e replaced in the future , my question is can anyone tell me ( without me crawling around under the car ) are these pipes able to be replaced with standard copper brake pipes ???? and what diameter is the pipe required are you from central Scotland by any chance? just I was talking to a mechanic in alloa yesterday and he said he had just done the brake pipes on a 350z yes i am from clackmannan and had the car mot done in alloa Quote Link to comment Share on other sites More sharing options...
The Chubby Ninja Posted May 27, 2013 Share Posted May 27, 2013 my 54 plate 350z has just failed the MOT due to brake lines excessivly corroded , had the garage replace the bad pipes but on returning home with the mot pass doc in the advisory section of the mot there are several more brake pipes required tob e replaced in the future , my question is can anyone tell me ( without me crawling around under the car ) are these pipes able to be replaced with standard copper brake pipes ???? and what diameter is the pipe required are you from central Scotland by any chance? just I was talking to a mechanic in alloa yesterday and he said he had just done the brake pipes on a 350z yes i am from clackmannan and had the car mot done in alloa cool ill keep an eye out for you and give you a wee wave if I see you Quote Link to comment Share on other sites More sharing options...
walt350z Posted November 7, 2013 Share Posted November 7, 2013 hi, i am from alloa to, must be a alloa thing just got a warning on my brake pipes at the mot. how did you get on with making your own ones up Quote Link to comment Share on other sites More sharing options...
The Chubby Ninja Posted November 7, 2013 Share Posted November 7, 2013 hi, i am from alloa to, must be a alloa thing just got a warning on my brake pipes at the mot. how did you get on with making your own ones up Do you have a silver zed? Quote Link to comment Share on other sites More sharing options...
