thirdearl Posted May 9, 2007 Share Posted May 9, 2007 has anyone got a view of the IPDM E/R . the service/parts cd i have does not have this file in it,i want to know what relays/fuses operate the wipers.or if anyones have stopped working,how did u cure it. cheers Quote Link to comment Share on other sites More sharing options...
MickJ Posted May 9, 2007 Share Posted May 9, 2007 has anyone got a view of the IPDM E/R . the service/parts cd i have does not have this file in it,i want to know what relays/fuses operate the wipers.or if anyones have stopped working,how did u cure it. cheers I have it on screen now, how can I get it to you? Quote Link to comment Share on other sites More sharing options...
MickJ Posted May 9, 2007 Share Posted May 9, 2007 FRONT WIPER AND WASHER SYSTEM PFP:28810 Components Parts and Harness Connector Location AKS000Y6 System Description AKS000Y7 All front wiper relays (HI, LO) are included in IPDM E/R. Wiper switch (combination switch) is composed of a combination of 5 output terminals and 5 input terminals. Terminal combination status is read by BCM when switch is turned ON. BCM controls front wiper LO, HI, and INT (intermittent) operation. IPDM E/R operates wiper motor according to CAN communication signals from BCM. Power is supplied at all times through 40 A fusible link (letter F, located in fusible link box.) to BCM terminal 7, through 20 A fuse [No.74 located in IPDM E/R (intelligent power distribution module engine room)] to front wiper relay [built in IPDM E/R (intelligent power distribution module engine room)] through 15 A fuse [No.73 located in IPDM E/R (intelligent power distribution module engine room)] to IPDM E/R (CPU). When the ignition switch ON or START position, power is supplied through 10 A fuse [No.1 located in fuse block (J/B] to BCM terminal 35 and. through 10 A fuse [No.80, located in IPDM E/R (intelligent power distribution module engine room)] to front wiper relay [built in IPDM E/R (intelligent power distribution module engine room)] and to front wiper high relay [built in IPDM E/R (intelligent power distribution module engine room)] and through 10 A fuse [No.87 located in IPDM E/R (intelligent power distribution module engine room)] through IPDM E/R terminal 18 to front washer motor terminal 2. Ground is supplied SKIA3235E Quote Link to comment Share on other sites More sharing options...
thirdearl Posted May 10, 2007 Author Share Posted May 10, 2007 cheers lads but the bloody motors destroyed itself inside 22k and its ****ed,posted a wanted,but if anyone has one Quote Link to comment Share on other sites More sharing options...
MickJ Posted May 10, 2007 Share Posted May 10, 2007 Try him he's breaking a 350Z might be worth a call, Ebay item #: 230127442792 Quote Link to comment Share on other sites More sharing options...
