TOM'S_ZED Posted May 21, 2013 Share Posted May 21, 2013 When fitting Decats is the original bracket which mounts to the cat and gearbox used reason I ask is mine has rotted through and broke away from the right hand cat Quote Link to comment Share on other sites More sharing options...
Keyser Posted May 21, 2013 Share Posted May 21, 2013 If the de-cats have the mounts it can be used - I don't use it on my setup, de-cats are lighter so need less support than the OEM cats which are bloomin heavy. So if it looks OK and is solid you can get away without, if in doubt or you want the extra support get a new one Quote Link to comment Share on other sites More sharing options...
The Chubby Ninja Posted May 21, 2013 Share Posted May 21, 2013 (edited) Depends on what decats. My first japspeed ones had a bracket but once they snapped the replacement ones didnt have one and neither did the silenced ones. Ive just took my bracket off Edited May 21, 2013 by The Chubby Ninja Quote Link to comment Share on other sites More sharing options...
TOM'S_ZED Posted May 21, 2013 Author Share Posted May 21, 2013 sweet good enough for me then cheers folks Quote Link to comment Share on other sites More sharing options...
MartynB85 Posted May 21, 2013 Share Posted May 21, 2013 What decats are you fitting? Can you do them on your back easily enough? Quote Link to comment Share on other sites More sharing options...
TOM'S_ZED Posted May 21, 2013 Author Share Posted May 21, 2013 Haven't bought any yet mate but been underneath and looks easy enough to do on your back if like mine and all your nuts are corroded up then it might be a pain though Quote Link to comment Share on other sites More sharing options...
MartynB85 Posted May 21, 2013 Share Posted May 21, 2013 I had a quick look a few weeks ago, the bolt heads are very corroded, they actually look completely round Quote Link to comment Share on other sites More sharing options...
TOM'S_ZED Posted May 21, 2013 Author Share Posted May 21, 2013 same as mine snap on do a fantastic kit for those situations a bit like these http://www.machinemart.co.uk/shop/product/details/5-piece-bolt-grip-set/path/ Quote Link to comment Share on other sites More sharing options...
MartynB85 Posted May 21, 2013 Share Posted May 21, 2013 cheers for these heads up, i'll grab a set of those before i attempt to fit the decat's. Quote Link to comment Share on other sites More sharing options...
TOM'S_ZED Posted May 21, 2013 Author Share Posted May 21, 2013 If that don't work grind them off and put a new nut and bolt through the flanges Quote Link to comment Share on other sites More sharing options...
Keyser Posted May 21, 2013 Share Posted May 21, 2013 (edited) You're not looking at the wrong side are you? The OEM Cats to Y pipe has 2 captive bolts so one side is round and welded in, the other side is the nut - which I grant you mat well be corroded to nothing much - grinder time. The top joints to manifold IIRC 2 point down and 1 up - you can with a "wobble" bar or UJ and extension bar get to them from the top with the help of "a Buster"* or other mate * a Buster = the largest but possibly most useful tool in the Zed Shed Edited May 21, 2013 by Keyser Quote Link to comment Share on other sites More sharing options...
TOM'S_ZED Posted May 21, 2013 Author Share Posted May 21, 2013 Luckily for me I'm having a custom header back system made so that will be the exhaust guys headache thankfully as this kind of thing stresses me out Quote Link to comment Share on other sites More sharing options...
MartynB85 Posted May 21, 2013 Share Posted May 21, 2013 Any ideas where i can get a set of silenced decat pipes? Ordered some from H-Dev but they don't have stock at the moment and a quick search hasn't found much.... Quote Link to comment Share on other sites More sharing options...
TOM'S_ZED Posted May 22, 2013 Author Share Posted May 22, 2013 Abbey do them I think but probably have to order them in and tarmac sports does them aswell I think Quote Link to comment Share on other sites More sharing options...
MartynB85 Posted May 22, 2013 Share Posted May 22, 2013 Didn't think of Abbey, i'll give them a call. I'm after a silenced one, Tarmac don't do those ones. Quote Link to comment Share on other sites More sharing options...
TOM'S_ZED Posted May 22, 2013 Author Share Posted May 22, 2013 There just of top of my head to be honest Quote Link to comment Share on other sites More sharing options...
