smudgedon Posted May 19, 2013 Share Posted May 19, 2013 Removed my plenum spacer earlier, everything back in place as normal When starting the engine, it coughs and splutters and has to be given a little throttle to keep it going and there's a horrendous screaming coming from the engine, sounds like a boiling kettle whistling away Checked everything twice now, throttle body all linked up to the intake, all bolts for the plenum done up and vacuum hose is in place Help me please! Quote Link to comment Share on other sites More sharing options...
aidan Posted May 19, 2013 Share Posted May 19, 2013 Check none of the hoses are kinked when you where refitting them. Does sound like a leak though. Quote Link to comment Share on other sites More sharing options...
jumping350 Posted May 19, 2013 Share Posted May 19, 2013 (edited) Maf sensor plugged in? And undamaged? Squeaky could be belts?or any eml lights? Edited May 19, 2013 by jumping350 Quote Link to comment Share on other sites More sharing options...
Tarmac@TarmacSportz Posted May 19, 2013 Share Posted May 19, 2013 As above it has to be a leak somewhere, did you torque the bolts up on the plenum to the correct settings ? I know a certain member who cracked the plenum from over tightening Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted May 19, 2013 Share Posted May 19, 2013 Some people trap hoses or other items between the plenum when refitting, leaving a leak. Also check all hoses are reconnected. Quote Link to comment Share on other sites More sharing options...
smudgedon Posted May 19, 2013 Author Share Posted May 19, 2013 Crisis averted The rubber seal around the oil cap was caught between the upper and lower plenum Mods can delete this if they want Quote Link to comment Share on other sites More sharing options...
Ekona Posted May 19, 2013 Share Posted May 19, 2013 Or keep it here so that others don't make the same mistake Quote Link to comment Share on other sites More sharing options...
glrnet Posted May 19, 2013 Share Posted May 19, 2013 It's happened before and it will happen again, we'll keep it as it's a useful reminder to others Glad you sussed it though Smudge Quote Link to comment Share on other sites More sharing options...
