greasemonkey1234 Posted May 17, 2013 Share Posted May 17, 2013 Hi All, I was driving at the weekend, and all of a sudden my oil pressure shot passed the max reading, which if a genuine pressure reading would have meant the engine would have gone pop! The car is running fine apart from the gauge having gone bonkers. I figure its either an earthing issue or some detioration of the electrical connection in the gauge. I'm not sure what the main problem is but was wondering if anyone else has had a similar problem? Cheers, Al Quote Link to comment Share on other sites More sharing options...
a2orry Posted May 17, 2013 Share Posted May 17, 2013 could be a faulty oil pressure sender .if the oil pressure gets way to high i would assume it might blow the filter can off of its mounting plate. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 18, 2013 Share Posted May 18, 2013 Sounds like an oil pressure sensor issue. New and preowned oil pressure sensor switches are in stock and good to go same/next day if required. Just drop me a pm if I can help you further with this mate. Alex. Quote Link to comment Share on other sites More sharing options...
greasemonkey1234 Posted May 18, 2013 Author Share Posted May 18, 2013 Thanks for your help guys! Getting the multimeter on the sensor it appears to be reading fine, so I'm thinking it maybe an earthing issue somewhere? Agree that if the oil pressure was genuinely that high or had gone that high then the engine would have stalled and hoses would have popped off lol. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 18, 2013 Share Posted May 18, 2013 If you disconnect the wire to the switch and earth it and the gauge goes off the scale then your issue will more than likely be the sender switch. Alex. Quote Link to comment Share on other sites More sharing options...
greasemonkey1234 Posted May 20, 2013 Author Share Posted May 20, 2013 Thanks Alex, I shall give this a try. Quote Link to comment Share on other sites More sharing options...
