gareth29 Posted May 11, 2013 Share Posted May 11, 2013 Anyone know how to do this? I assume you need an obd thingy? Mine idles at around 650rpm, a bit lumpily and easy to stall as a result (thats wot i'm blaming anyway). Strangely tho, my manual suggests an idle speed of 650. Quote Link to comment Share on other sites More sharing options...
evilscorp Posted May 11, 2013 Share Posted May 11, 2013 You can either get it done at the dealer or with an uprev remap. Not sure if you can do it yourself. Quote Link to comment Share on other sites More sharing options...
The Chubby Ninja Posted May 11, 2013 Share Posted May 11, 2013 Have you tried a throttle body reset? Or maybe cleaning the maf sensor? Quote Link to comment Share on other sites More sharing options...
Chris AME Posted May 11, 2013 Share Posted May 11, 2013 It can be done on nissan consult Quote Link to comment Share on other sites More sharing options...
Toon Chris Posted May 11, 2013 Share Posted May 11, 2013 (edited) Put the aircon on and it will idle higher. Not a solution but stops it trying to stall. I'd suggest you have a dirty throttle body and a clean of that and a reset should do the trick. Its the cheapest option so worth doing first. After that you may have worn plugs, are they due for changing? Edited May 11, 2013 by Toon Chris Quote Link to comment Share on other sites More sharing options...
gareth29 Posted May 11, 2013 Author Share Posted May 11, 2013 Thanks, done a tb reset and cleaned it recently, also new plugs - could try cleaning the maf, but it looks ok and very fragile! Are the nissan consults on ebay ok? eg this one http://www.ebay.co.uk/itm/Nissan-Consult-Diagnostic-Interface-Cable-Tool-obd-14-Pin-/121108557944?pt=UK_Diagnostic_Tools_Equipment&hash=item1c32a1f078 Quote Link to comment Share on other sites More sharing options...
Chris AME Posted May 11, 2013 Share Posted May 11, 2013 The consults I meant were like what we use ie 2, 3 and3+ no experience with those of ebay Quote Link to comment Share on other sites More sharing options...
cs2000 Posted May 13, 2013 Share Posted May 13, 2013 Ive done some further reading on those eBay ones and found this, but looks like those ebay type ones wont work with the Z. I could be talking out of my A$$ though It works on all Nissan cars that have the grey 14pin Consult connector (you'll usually find it near the fusebox) (This cars are usually build from year 1989 to 2000) . Models such as: 300ZX, Z32, Maxima, 240SX, S13, S14, Skyline, SR20DE, SR20DET, RB20, Altima, Fairlady. Quote Link to comment Share on other sites More sharing options...
glrnet Posted May 13, 2013 Share Posted May 13, 2013 Thanks, done a tb reset and cleaned it recently, also new plugs - could try cleaning the maf, but it looks ok and very fragile! Are the nissan consults on ebay ok? eg this one http://www.ebay.co.u...=item1c32a1f078 Buy some electrical contact cleaner form halfrauds and use this on the maf, do not touch the "wires" inside Quote Link to comment Share on other sites More sharing options...
cs2000 Posted May 13, 2013 Share Posted May 13, 2013 Ive also used carb cleaner (just because I had it to hand) and that worked too. Was always advised not to direct the spray of fluid at the actual sensor, more on the material around it and let it splash onto the sensor itself. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted May 13, 2013 Share Posted May 13, 2013 I just leave the aircon on which ups the tickover which isnt a bad thing anyway to prevent bacteria build in then aircon and rubber pipes from cracking. Quote Link to comment Share on other sites More sharing options...
Dblock Posted May 13, 2013 Share Posted May 13, 2013 Do the idle air relearn. It will sort your idle problems out Quote Link to comment Share on other sites More sharing options...
gareth29 Posted May 13, 2013 Author Share Posted May 13, 2013 Thanks, tried the ac trick - no joy, maybe my ac isnt working, i also tried the idle air learn at the same time as the tb reset. Looks like a visit to a specialist. Quote Link to comment Share on other sites More sharing options...
Dblock Posted May 13, 2013 Share Posted May 13, 2013 Thanks, tried the ac trick - no joy, maybe my ac isnt working, i also tried the idle air learn at the same time as the tb reset. Looks like a visit to a specialist. Did you deffo do it though? It's a proper pain to get right. Quote Link to comment Share on other sites More sharing options...
gareth29 Posted May 13, 2013 Author Share Posted May 13, 2013 You're right it is a pita, but eventually i got the sequence of pedal pushes and timings right - timed with a stopwatch Quote Link to comment Share on other sites More sharing options...
