Jp606 Posted May 11, 2013 Share Posted May 11, 2013 Hi, Have just purchased a HR Z and like most out there the drivers interior window switch plastic trim has scratches all over it. Does anyone know where I can source a replacement? I guess I could remove it and respray it but it seems far easier to just get a replacement. Cheers. Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted May 11, 2013 Share Posted May 11, 2013 A bit of wet & dry, a rattle can of satin black is way cheaper than replacements, plus the chuffed factor alone is worth it Quote Link to comment Share on other sites More sharing options...
Mopedmark Posted May 11, 2013 Share Posted May 11, 2013 Why buy a new one when it takes a couple of minutes to take apart,which you would have to do anyway to replace.As BulletMagnet said paint it yourself then you will have a nice little custom piece and you will feel good about it Quote Link to comment Share on other sites More sharing options...
tc350z Posted May 11, 2013 Share Posted May 11, 2013 As the above says, far more expensive to replace why no spray it to a colour of your choice or even wrap it in carbon fibre effect? But if you really want new ones then suppose ZMANALEX would be your best shout. Quote Link to comment Share on other sites More sharing options...
jonny the mod Posted May 11, 2013 Share Posted May 11, 2013 Ive got the same problem on my new zed jp. Ive seen pics of them after they have been sprayed and wrapped and they look great. My only worry is how easy it is to remove the said pannel (would you have to remove the door card!!). Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted May 11, 2013 Share Posted May 11, 2013 Ive got the same problem on my new zed jp. Ive seen pics of them after they have been sprayed and wrapped and they look great. My only worry is how easy it is to remove the said pannel (would you have to remove the door card!!). Very easy, no screws, just clips along the side to attach it to the door card. First remove the armrest pad by lifting from the rear and then the switch panel 1 Quote Link to comment Share on other sites More sharing options...
Tinyflier Posted May 11, 2013 Share Posted May 11, 2013 Ive got the same problem on my new zed jp. Ive seen pics of them after they have been sprayed and wrapped and they look great. My only worry is how easy it is to remove the said pannel (would you have to remove the door card!!). No door card removal. Have a search on this forum for details but in summary - remove the leather arm rest, unclip the switch cover, undo the switches - job done. Best to get yourself some trim removal (plastic) tools (a few pounds from FleaBay) to be able to get into the joints without scratching anything. Painting them really doesn't take long and if you do it once, then should you scratch them again - easy fix as you know what to do! David 1 Quote Link to comment Share on other sites More sharing options...
Bobbyheinz Posted May 11, 2013 Share Posted May 11, 2013 For those that have repainted - did you use primer or just wet/dry and then paint? Quote Link to comment Share on other sites More sharing options...
Stutopia Posted May 11, 2013 Share Posted May 11, 2013 (edited) I'm a total mechanical spanner (not in a good way) took me about 5 minutes to get out with zero damage to adjoining bits. I plastidipped mine after a clean, no good, finish isn't robust enough. Black satin next time. As others have said, I was well pleased with myself when I did just this little tiny job. I'm hoping its the first step to learning more and having a more personal touch to my car. I chopped up my speaker grilles shortly after, pleased with that too. If you give it a try and it goes bad, you can still buy another, assuming you don't destroy the door! GL. +1 on trim removers, much better than improvising and dirt cheap, useful for all sorts. Check out http://www.350z-uk.com/topic/56633-interior-door-trim-mirror-switch-scratch-repaint/page__hl__plastikote#entry839492 Edited May 11, 2013 by SuperStu 1 Quote Link to comment Share on other sites More sharing options...
richmillions Posted May 11, 2013 Share Posted May 11, 2013 I might give this a go on mine tomorrow, was looking at getting them hydro dipped but any company I've message hasn't replied. That guide is handy. Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted May 11, 2013 Share Posted May 11, 2013 I might give this a go on mine tomorrow, was looking at getting them hydro dipped but any company I've message hasn't replied. That guide is handy. RT Customz has hydro dipped ones ready to go on exchange basis Quote Link to comment Share on other sites More sharing options...
Tinyflier Posted May 11, 2013 Share Posted May 11, 2013 For those that have repainted - did you use primer or just wet/dry and then paint? After sanding the chips and scratches smooth I used plastic primer (two coats) then when dry a light going over with 2000 grade wet and dry then I think three top coats. David Quote Link to comment Share on other sites More sharing options...
Mopedmark Posted May 11, 2013 Share Posted May 11, 2013 If you want to make them really trick and colour them you can use clear lacquer after base coat at least 3 coats but more the merryer Quote Link to comment Share on other sites More sharing options...
LewisH Posted May 12, 2013 Share Posted May 12, 2013 Some methods can be seen here: http://www.350z-uk.com/topic/63189-interior-restoration/ I wrapped mine, it's not easy but gives you a really nice smooth vinyl finish. Quote Link to comment Share on other sites More sharing options...
jonny the mod Posted May 12, 2013 Share Posted May 12, 2013 I know that this wasnt my thread, but thanks guys for your help.. will give it a go later on (im off to see jetset, I will rope him in !!) Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted May 12, 2013 Share Posted May 12, 2013 Got 2 sets of the pre facelift switch handles for exchange http://www.350z-uk.com/topic/70886-rtcustomz-interior-arm-rests-80/ if that's any help. Other parts also available http://www.350z-uk.com/topic/70889-rtcustomz-price-list-and-product-links/ Quote Link to comment Share on other sites More sharing options...
richmillions Posted May 12, 2013 Share Posted May 12, 2013 I might give this a go on mine tomorrow, was looking at getting them hydro dipped but any company I've message hasn't replied. That guide is handy. RT Customz has hydro dipped ones ready to go on exchange basis Not for the facelift unfortunately otherwise I would have taken a set Quote Link to comment Share on other sites More sharing options...
