Aran20 Posted May 10, 2013 Share Posted May 10, 2013 Just bought a 350Z, so new to the joys of owning one. At what revs should the Rev limiter light normally indicate? Quote Link to comment Share on other sites More sharing options...
OsakaBen Posted May 10, 2013 Share Posted May 10, 2013 You can change it via the button on the side of the speedo, I set mine a 6600 rpm, so I can drive it harsh but not hit the limiter Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted May 10, 2013 Share Posted May 10, 2013 The light merely indicates, it does not actually set the rev limit Quote Link to comment Share on other sites More sharing options...
Aran20 Posted May 10, 2013 Author Share Posted May 10, 2013 thanks... Was worried as mine seemed to be illuminating at 3000 - 4000 rpm that seemed low, but thats what the last owner must have set it too. Quote Link to comment Share on other sites More sharing options...
Tinyflier Posted May 10, 2013 Share Posted May 10, 2013 (edited) You can change it via the button on the side of the speedo, I set mine a 6600 rpm, so I can drive it harsh but not hit the limiter On the multifunction gauge scroll to the last "page" and you will see the what the rev value light illumination is set at. As OsakaBen has advised you can then adjust it using the buttons on the left side of the instrument cowl. David Edited May 10, 2013 by Tinyflier Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 10, 2013 Share Posted May 10, 2013 After a while you will not even notice it. Alex. Quote Link to comment Share on other sites More sharing options...
