Losing Traction - Falken FK453
JackStrong
Hi,
So i previously had Kumho's on all round. Came with the car.
Last month i replaced the rears with FK453's along with new drops links all around.
I just seem to be losing the back end when going around bends at ~40mph, only for a slight second before the traction control light has an epileptic fit and the car gets grip.
Suggestions ? :wacko:
is this mainly on wet roads? falkens are quite a hard rubber if they are the same as they where years ago when I had them, Kumho's are very soft and grippy but wear quick its most likely the sacrifice for performance vs economy lol
I've just replaced my 452's with 453's all round, and I've noticed they don't seem to grip as much when cornering hard, theres that stage where it looses grip before grabbing on. As said dunno if its the release agent so need to wait, but I've spent the £ there staying on now! :lol:
Check your alignment too, could well be that something hasn't been set right after the droplinks were installed and they've given you a different setup to the one you had previously.
