Shaun1982 Posted May 4, 2013 Share Posted May 4, 2013 Fitted a new window motor from Alex finally. All seemed well until I noticed after a while the window isn't going up & down when you open the door. Tried doing the reset but without holding the reset button in the window only goes up an inch. Help please Quote Link to comment Share on other sites More sharing options...
KC350Z Posted May 4, 2013 Share Posted May 4, 2013 check the switch/button that the door presses to operate the window drop against and see if that's working also how do you do reset without pressing the button Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted May 4, 2013 Author Share Posted May 4, 2013 I was trying the reset ' window up doke closed. Hold switch, drop glass manually. Let go of switch at the bottom. Return window up' except that's when it won't go higher than an inch. Hold the switch again & it will go up Quote Link to comment Share on other sites More sharing options...
