NGK Iridium Spark plugs Standard and One Step Colder
Nos/Supercharger/Turbo customers usually request One step colder plugs:
Not my words and maybe slightly out of context:
Anytime you run boost, or a high compression engine, you want to use colder spark plugs than stock. Basically you've got a piece of metal sitting in your cylinder that is searingly hot. The right amoutns of Heat + Fuel + Pressure = Combustion.
Now, if that plug is too hot, then it will preignite the fuel too early, and cause that ever so nasty situation called "Detonation" which can lead to your whole engine going KABOOM. And thats a bad thing.
Here you go Chubbs:
LASER IRIDIUM®
Laser Iridium® spark plugs provide superior ignitability and long service life.  Smallest tip diameter available Iridium / Platinum surfaces ensure slow wear rate providing stable idle, superior anti fouling, improved fuel efficiency and lower emissions
Laser welded Iridium center electrode tip
Platinum disc welded to backside of ground electrode provides long life
Trivalent Metal Plating for superior anti-corrosion and anti-seizing
Faster starts and quicker acceleration
Better fuel economy and lower emissions
Best OEM Iridium spark plug available
Original Equipment Manufacturer approved design
DE I'm afraid Dip, Im always neglecting you HR boys I know
Out of interest Chris, and to save my ignorance next time, what is the difference between DE and HR plugs? Is it just size?
Here you go Chubbs:
LASER IRIDIUM®
Cheers chris. Most of that went straight over my head apart from the word "faster" :lol: . Il take a set of the laser colder ones off you but wont be til next week. Il give you a pm next week mate cheers
Size and HR OEM plugs are Iridium, our very own mr AK350Z did an install guide on the HR:
http://www.350z-uk.com/topic/32951-spark-plug-change-vq35hr-my07/
