Dashurik Posted April 29, 2013 Share Posted April 29, 2013 (edited) Hi,folks! Today when I started my car it took a bit longer to start,a bit of struggle I would say...Switch off /on few more time ,no problem..But now I can hear some whistling noise under the car,it's on and off ,sound like some air escape or similar..I can also hear this whistling noise inside the car,it gives me a slight headache... I spoke to Sly from kaizermotor ,he told me the only way to check what's wrong is to visit him,80 miles tround trip...He pretty busy and only can check it and if something serious then next appointment. Anybody had similar issues ?? Edited April 29, 2013 by Dashurik Quote Link to comment Share on other sites More sharing options...
Keyser Posted April 29, 2013 Share Posted April 29, 2013 Does the noise change if/when you press the clutch - just wondered if it is the thrust bearing - pure guess - but what else is in the middle of the car Hole in the zorst ?? Quote Link to comment Share on other sites More sharing options...
Dashurik Posted April 29, 2013 Author Share Posted April 29, 2013 (edited) Does the noise change if/when you press the clutch - just wondered if it is the thrust bearing - pure guess - but what else is in the middle of the car Hole in the zorst ?? Not sure ,I bent under the car and can clearly hear it,it's stops and start,not constant..BUt inside the car it's constant and noise comes out from the subwoofer(behind seat,gt model) area...It like high frequency sound,annoying a bit.. Might be zorst as I had problem few month ago,think was welded ....I have to admit that might exaust looks pretty @*!#,lots of rust...NOticed it when was doing p3 in SLy garage.. Edited April 29, 2013 by Dashurik Quote Link to comment Share on other sites More sharing options...
