The Chubby Ninja Posted April 28, 2013 Share Posted April 28, 2013 hi everyone, im having a slight problem with the clutch. when pressing the pedal in and out theres a loud squeak/creek. It doesn't sound like its inside the clutch and its not in the cabin. is there anywhere I can put oil or grease on to stop this? ive tried searching but cant come up with anything. any help would be appreciated cheers. Steve Quote Link to comment Share on other sites More sharing options...
narcotix Posted April 29, 2013 Share Posted April 29, 2013 I have a similar issue but mine does sound like it's comming from the inside the car... Quote Link to comment Share on other sites More sharing options...
Dave_the_Rave Posted April 29, 2013 Share Posted April 29, 2013 The dreaded clutch squeak! i had this but for some unknown reason it dissappeared!! sometimes happens but rarely... when it was bad i was worried but cant imagine its anything too serious Quote Link to comment Share on other sites More sharing options...
evilscorp Posted April 29, 2013 Share Posted April 29, 2013 Had the same problem after fitting my carbon bonnet with vents, the water runs down the engine,gearbox and removes the grease from the clutch cylinder. Cars after 05? Have it built inside the bell housing or something but older cars like mine is visible from under the car and easy enough to grease. At work so cant upload a pic but if you need more info I will help you out later with one. Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted April 29, 2013 Share Posted April 29, 2013 I've searched this and there ARE threads you fibber white grease from halfords - press pedal down and squirt/dab some on at the joints - probably need to do it a few times over a month until it's worked in. Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted April 29, 2013 Share Posted April 29, 2013 Yep white greaseis the best as WD40 etc only lasts a few days at best. You need to position youself with your head down by the pedals facing up with a torch and you are looking for the spring on the clutch pedal, give it a nice soaking once a week for a month and you will be amazed how nice and smooth the clutch travel is and how quiet it is Quote Link to comment Share on other sites More sharing options...
Stutopia Posted April 29, 2013 Share Posted April 29, 2013 Footwell clutch spring grease cured this for me. Quote Link to comment Share on other sites More sharing options...
Dave_the_Rave Posted April 29, 2013 Share Posted April 29, 2013 Had the same problem after fitting my carbon bonnet with vents, the water runs down the engine,gearbox and removes the grease from the clutch cylinder. Cars after 05? Have it built inside the bell housing or something but older cars like mine is visible from under the car and easy enough to grease. At work so cant upload a pic but if you need more info I will help you out later with one. if you could upload a photo this would be great! as mine was a sound which was not related to the pedal or spring a sound which could be heard from inside and more so outside Quote Link to comment Share on other sites More sharing options...
evilscorp Posted April 29, 2013 Share Posted April 29, 2013 (edited) If you type 350z clutch cylinder into google images you will see pics of it and where it is, just pull back the rubber boot and apply grease. Edited April 29, 2013 by evilscorp Quote Link to comment Share on other sites More sharing options...
The Chubby Ninja Posted April 29, 2013 Author Share Posted April 29, 2013 Thanks for the help everyone its much appreciated. Il give it a try this weekend. I hope it does fix it as its pretty embarrassing . Rob i did search i promise, even searched google Quote Link to comment Share on other sites More sharing options...
evilscorp Posted April 29, 2013 Share Posted April 29, 2013 I didn't want to drive the car mine sounded that bad! Now I just dont drive her in the wet Quote Link to comment Share on other sites More sharing options...
georgerobertfreeman Posted May 6, 2013 Share Posted May 6, 2013 I have the same problem after jet washing the arches. Its a loud squeak that is coming from under the car when releasing the clutch pedal. I hope its as simple as applying some grease! Quote Link to comment Share on other sites More sharing options...
The Chubby Ninja Posted May 6, 2013 Author Share Posted May 6, 2013 ive not got round to trying the fix yet as its kind of going away. next time im under im going to give it a skoot Quote Link to comment Share on other sites More sharing options...
