JDM Performance Posted May 2, 2007 Share Posted May 2, 2007 Just back into stock today are the SATIN versions of the front/rear Z badges. But that's not all - we have managed to reduce our prices too! Now just £30 each! Available from our site here: http://www.funkystyling.co.uk/item_deta ... =449006483 Quote Link to comment Share on other sites More sharing options...
Beavis Posted May 2, 2007 Share Posted May 2, 2007 Thats a very good price, i would advise anyone thinking of getting these to be quick because last time we did a group buy we paid more. Quote Link to comment Share on other sites More sharing options...
sl114 Posted May 2, 2007 Share Posted May 2, 2007 They are awesome! A good buy for some people there Quote Link to comment Share on other sites More sharing options...
MAB Posted May 2, 2007 Share Posted May 2, 2007 order placed !!!! mmmmmmmmmm javascript:emoticon(':yahoo:') Yahoo Quote Link to comment Share on other sites More sharing options...
MAB Posted May 4, 2007 Share Posted May 4, 2007 Ok , now they are here, brilliant service I must say. Now the numpty in me asks, what is the best way of getting the "Nissan" badges off and replacing them with the "Z" javascript:emoticon(':headhurt:') Headhurt Quote Link to comment Share on other sites More sharing options...
Beavis Posted May 4, 2007 Share Posted May 4, 2007 Ok , now they are here, brilliant service I must say.Now the numpty in me asks, what is the best way of getting the "Nissan" badges off and replacing them with the "Z" javascript:emoticon(':headhurt:') Headhurt Here you go http://www.350z-uk.com/forum/viewtopic.php?t=1632 Quote Link to comment Share on other sites More sharing options...
MAB Posted May 4, 2007 Share Posted May 4, 2007 Thanks Beavis,I'll get my hairdryer and dental floss out.javascript:emoticon(':blush:') Blush Quote Link to comment Share on other sites More sharing options...
Chesterfield Posted May 4, 2007 Share Posted May 4, 2007 This is how Ive done it twice. Hairdryer - low-medium heat for a breif period, just to try and get the glue tacky (whether it really helps or not I dont know). Then use dental floss as a cheesewire to "cut" them off. Ensure you angle the dental floss such that it does NOT run against the bodywork, just the bade itself. (tricky on the front, but just be patient). It may take half a roll of dental floss depending on how strong it is, and it may also take a while - just be patient. Once the badge is off, you have some majory picking at the leftover sticky glue/pad to do, dont rub and rub at it with your thumbs/fingers - unless you have super hard fingers or enjoy blisters for a week. - Use your nail (carefuly) and again it will take a while. Also, applying furniture polish and allowing it to soak into the sticky foam then rubbing with a cloth will make removing the leftover easier - just wipe any excess polish from the bodywork whilst allowing it to soak into the foam. On the rear badge, before you start I would advise marking the position of the badge by placing masking tape either side and marking points on the masking tape with a pencil. That way you know the new badge will be lined up in the centre without trying to guess it - or measure from either side of the boot. All in - give yourself 1.5 hours to chage these including making a good job of picking off all the leftover sticky pad/glue from the car left by the existing Nissan badges. Quote Link to comment Share on other sites More sharing options...
Trev-the-Rev Posted May 4, 2007 Share Posted May 4, 2007 Dude you're a perfectionist I shall know who to do mine if I decide to change them Quote Link to comment Share on other sites More sharing options...
Sarnie Posted May 4, 2007 Share Posted May 4, 2007 This is how Ive done it twice. Hairdryer - low-medium heat for a breif period, just to try and get the glue tacky (whether it really helps or not I dont know). Then use dental floss as a cheesewire to "cut" them off. Ensure you angle the dental floss such that it does NOT run against the bodywork, just the bade itself. (tricky on the front, but just be patient). It may take half a roll of dental floss depending on how strong it is, and it may also take a while - just be patient. Once the badge is off, you have some majory picking at the leftover sticky glue/pad to do, dont rub and rub at it with your thumbs/fingers - unless you have super hard fingers or enjoy blisters for a week. - Use your nail (carefuly) and again it will take a while. Also, applying furniture polish and allowing it to soak into the sticky foam then rubbing with a cloth will make removing the leftover easier - just wipe any excess polish from the bodywork whilst allowing it to soak into the foam. On the rear badge, before you start I would advise marking the position of the badge by placing masking tape either side and marking points on the masking tape with a pencil. That way you know the new badge will be lined up in the centre without trying to guess it - or measure from either side of the boot. All in - give yourself 1.5 hours to chage these including making a good job of picking off all the leftover sticky pad/glue from the car left by the existing Nissan badges. 1.5 hours Quote Link to comment Share on other sites More sharing options...
Chesterfield Posted May 4, 2007 Share Posted May 4, 2007 Seems the glue/sticky pads were a bit of a pain to get off on mine! You can do it much quicker if you rush the job, but thats how the things get put on upside down. Quote Link to comment Share on other sites More sharing options...
rmmackfc Posted May 5, 2007 Share Posted May 5, 2007 I used the dental floss method replacing mine I only had one issue, there were two raised 4mm diameter round bits of plastic under the original badge, ie part of the moulding for the bumper. Needless to say my car only now has one of these ....dental floss cuts through plastic ....use carefully Quote Link to comment Share on other sites More sharing options...
