How low before adjustable camber arms
aidan
As per title, how low can you go spring wise before you need adjustable camber arms.
Want to lower a little, but don't want expense of camber arms.
Also most springs seem to drop about 30mm (which I assume would need camber arms)?
Any make lower a little less?
Its for a roadster (if that matters)...which I think it must as tein list different part numbers for coupe and roadster. Probably cause the roadster has a lardy ass.
