BY PASS WATER HOSE
Payco
All
After some advice. I want to fit a replacement by pass water hose on my zed. Can someone advise if i need to drain anything before i fit it or can i just remove the stock one (when the car is cold) and replace it with the new.
Thanks
Payco
If it's above the rest of the system then you should be OK... Or you could plug the holes with something (Keep in clean now gents, this is a family forum! :teeth: )?
Someone who actually knows what the hell they're talking about will correct me shortly no doubt!
Thanks Paddy. Will wait to hear what others say. Just a bit nervous of pulling them off and then seeing my belts covered in coolant. Will put some towels around the hose ends in case providing i can do this without having to drain the system.
Regards
Payco
