Best way to fit mesh
CrumbMC
I have looked for some guides on mesh fitting on the internet and most of them say screws. However unless i have screws visibly poking out im not sure how to do it that was. was thinking of maybe using epoxy.
does anyone have any reccomedations? the bumper is an EPRacing V2
pics here:
thats not a bad idea. i might actually use a glue gun or epoxy with sticky backs. the ones i have for work re only sticky enough for a few 1.5 mm cables. cheers guys. it would be removable with that too :)
You can get some "external" ones that will stick like . . . . to a brick B)
The proper way would be to use an epoxy resin and bond either some small ally strips on with holes drilled in the end to take cable ties. Or expoxy on some hard bendy wire that can then be fed through the meek and bent over to hold in place.
A fibre glass kit from halfrauds would work a treat.
Agreed - i fitted mesh to my, and the misses', MR2 Turbo's ages ago. We fitted mesh to the side air intakes - i shaped the mesh around the inner curves and the fibre glassed it into place. Once dry the mesh was not going anywhere!!
