Eibach 30mm Springs and Eibach 25/20mm spacers advice
mattfinch
Hi all
I'am looking to lower my car by 30mm but I also want 25mm spacers on the rear and 20mm spacers on the front.
If i put this sut up of spacers on my car and then lower by 30mm will I have any problems, such as rubbing or knocking?
Any help would be great.
Thanks
Once you've done a few miles after fitting the springs, get someone to check the camber and toe, sometimes it's a bit out and you'll need to buy an adjustable camber kit to bring it back into specs.
  • 4 weeks later...
I have this exact setup, have done for almost a year now...it's a great fitment and look, I had to get Eibach rear camber arms and bolts to adjust the rear and bring it all back in as the inner walls were running quite low. The only thing I would say, since being on track is the rear can be a bit bouncy - i'm now looking to upgrade to coilovers soon :)
