ioneabee Posted April 23, 2013 Share Posted April 23, 2013 I wonder what it could mean ??? on a serious note though - how does it know ? same as the air pressure monitor - there's no sensor into the trye .................. so how does it do that I'll just go my "it's magic" theory for now..........................unless anyone know different ps sorry about quality of pick - the road was bumpy and my sons hand is not steady reaching across there Quote Link to comment Share on other sites More sharing options...
Will370z Posted April 23, 2013 Share Posted April 23, 2013 (edited) Never had that, but logic would dictate you have low air pressure or a flat coming. Intersting question though, Must be a sensor somewhere Other than thaty it could just mean the car knows you have a wheel attached..... Edited April 23, 2013 by Will370z Quote Link to comment Share on other sites More sharing options...
stuarty Posted April 23, 2013 Share Posted April 23, 2013 Dont know if this helps, but on the BMW's sometimes if you hit a small pothole or bump the puncture warning light can come on! Quote Link to comment Share on other sites More sharing options...
ioneabee Posted April 23, 2013 Author Share Posted April 23, 2013 low air pressure is a different symbol Will methinks, I'm running out of rubber ??? - the rears are pretty thin on the outside edges (but fairly good on the inner edge), but I suspect I'm at the limit of the 25% tread rule ? Quote Link to comment Share on other sites More sharing options...
marzman Posted April 23, 2013 Share Posted April 23, 2013 No idea but perhaps it may work based on rolling radius'? It may detect a minor percentage difference on tolerable levels. The radius would be smaller if the tyre was losing air but the tpms would trigger and supercede this message. All just a theory. Quote Link to comment Share on other sites More sharing options...
ioneabee Posted April 23, 2013 Author Share Posted April 23, 2013 see - magic Quote Link to comment Share on other sites More sharing options...
Keyser Posted April 23, 2013 Share Posted April 23, 2013 It just knows you have done 10,000 miles on them so they need changing. Quote Link to comment Share on other sites More sharing options...
ioneabee Posted April 23, 2013 Author Share Posted April 23, 2013 17,000 (plus a bit) Quote Link to comment Share on other sites More sharing options...
Will370z Posted April 23, 2013 Share Posted April 23, 2013 Doubt its the amount of rubber, i let my rears get pretty low before changing as i wasnt using her much but i never saw that icon. Quote Link to comment Share on other sites More sharing options...
Harryjax Posted April 23, 2013 Share Posted April 23, 2013 Tyre replacement indicator. I think its worked out on mileage done by your tyres. You can set or reset this in you trip computer. Go to sub menu Maintenance. On there you can set distance reminders to change oil filter/ oil/ tyres. Hope this helps. Quote Link to comment Share on other sites More sharing options...
Wasso Posted April 23, 2013 Share Posted April 23, 2013 17,000 (plus a bit) 17k........... You don't drive hard enough. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted April 24, 2013 Share Posted April 24, 2013 Tyre replacement indicator. I think its worked out on mileage done by your tyres. You can set or reset this in you trip computer. Go to sub menu Maintenance. On there you can set distance reminders to change oil filter/ oil/ tyres. Hope this helps. This. I seem to remember there are a number of maintenance reminders you can set to certain milage/time values and it will remind you. Means it reminds you to check certain things like oil. coolant, tyres, etc. I'm betting thats what it is. On my old 370z I dont remember them being defined as certain things such as tyres etc, I just had reminder 1, 2, 3 and you had to remember what it was you're reminding yourself to check Quote Link to comment Share on other sites More sharing options...
TheMacDaddy Posted April 24, 2013 Share Posted April 24, 2013 (edited) From our cousins at the370z.com: http://www.the370z.com/wheels-tires/32582-maintenance-tires.html Edited April 24, 2013 by TheMacDaddy Quote Link to comment Share on other sites More sharing options...
ioneabee Posted April 24, 2013 Author Share Posted April 24, 2013 That would explain it - I had a low air pressure warning come up last week (after the alloys were repaired - he didn't inflate them enough) - so was fiddling with the setting trying to re-set the air pressure monitor ........ only it apparently doesn't need manually resetting Quote Link to comment Share on other sites More sharing options...
Ebized Posted April 24, 2013 Share Posted April 24, 2013 17,000 (plus a bit) Think the rest of the car will wear out before your tyres do Quote Link to comment Share on other sites More sharing options...
ioneabee Posted April 24, 2013 Author Share Posted April 24, 2013 or me Quote Link to comment Share on other sites More sharing options...
