crc350z Posted April 21, 2013 Share Posted April 21, 2013 Is the EML supposed light up during startup? In any other car ive had it does but on my zed is doesn't As I've never been in another one I don't know if this is normal or if the light isnt working Thanks Quote Link to comment Share on other sites More sharing options...
Will370z Posted April 21, 2013 Share Posted April 21, 2013 From memory all lights should show on startup then go off, others will confirm though im sure Quote Link to comment Share on other sites More sharing options...
saiper Posted April 21, 2013 Share Posted April 21, 2013 (edited) It lights up on mine then goes off upon full start. J. Edited April 21, 2013 by saiper Quote Link to comment Share on other sites More sharing options...
cs2000 Posted April 21, 2013 Share Posted April 21, 2013 yup normal :)I always assumed it was so MOT testers could check if the lights were all working. Quote Link to comment Share on other sites More sharing options...
Dave J Posted April 21, 2013 Share Posted April 21, 2013 Sounds like it's been removed? Quote Link to comment Share on other sites More sharing options...
crc350z Posted April 21, 2013 Author Share Posted April 21, 2013 Thanks, my fear was it had been removed but it looks like it has. Im having problems with the car and couldn't work out why I was getting no errors on the dash but now i know Quote Link to comment Share on other sites More sharing options...
Dave J Posted April 24, 2013 Share Posted April 24, 2013 What problems are you getting? I've had a few Evo's in that have had a de-cat fitted and the CEL have been removed as they stayed lit after this mod............if you have a similar issue you could replace the bulb and hopefully map the CEL out. If you don't have access to a code reader and are going to Japfest i can always put my 2 readers in the car so you can have a free look at what's going on Quote Link to comment Share on other sites More sharing options...
crc350z Posted May 10, 2013 Author Share Posted May 10, 2013 Problems appear to be linked to a throttle body that was badly needing cleaned and 2 front 02 sensors which were gone completely. It doesn't seem like enough to merit removing the bulb as they are pretty easy fixes Hopefully wont need a reader for a while Quote Link to comment Share on other sites More sharing options...
Dave J Posted May 11, 2013 Share Posted May 11, 2013 Happy days!! Quote Link to comment Share on other sites More sharing options...
