sl114 Posted April 30, 2007 Share Posted April 30, 2007 you are right Louis, depends on how the car is used. WRT Evos and Scoobys, those sccops and vents are all std from factory, hence any possible side effect (and most importantly, aerodynamic and cooling effects) has been taken into consideration by the car companies. That makes perfect sense. I presume you do not tell your insurance company that for a few days a year you have a different bonnet Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted April 30, 2007 Share Posted April 30, 2007 you are right Louis, depends on how the car is used. WRT Evos and Scoobys, those sccops and vents are all std from factory, hence any possible side effect (and most importantly, aerodynamic and cooling effects) has been taken into consideration by the car companies. That makes perfect sense. I presume you do not tell your insurance company that for a few days a year you have a different bonnet It would be an interesting one if you dropped one whilst changing them over for sure Val, I see what you are saying but I thought your bonnet was fully paintshielded anyhow, so it's just an image thing since there should be no damage to your 'daily' bonnet? Quote Link to comment Share on other sites More sharing options...
Removed Posted April 30, 2007 Share Posted April 30, 2007 I decided to paintshield only the new bumper mate, as it wasn't worth my while to do the new bonnet, for the above reasons. TBH the water leakage into the engine bay was the biggest reason i decided to just use the new bonnet as shows only Quote Link to comment Share on other sites More sharing options...
