kris Posted April 10, 2013 Share Posted April 10, 2013 (edited) So bolting a 10inch sub in the Bose subwoofer recess will sound terrible, it needs to be boxed etc. But would a free air subwoofer sound ok? I know alot of you audio perverts don't like free air subs, but a decent one with the recess dynamatted properly sounds like an easier option than custom building a box that will fit in the recess. So has this been done? Would it work? And before anybody says anything I don't want a sub in the boot, I would like it nice and tucked away. Edited April 10, 2013 by kris Quote Link to comment Share on other sites More sharing options...
Dblock Posted April 10, 2013 Share Posted April 10, 2013 If you realise it won't be as good then you do get quite a few infinte baffle/free air options. Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted April 11, 2013 Share Posted April 11, 2013 Go for it, many laughed at me for getting a flat sub with no box but those thaf have heard it laugh no more Quote Link to comment Share on other sites More sharing options...
glrnet Posted April 11, 2013 Share Posted April 11, 2013 He's right^ Quote Link to comment Share on other sites More sharing options...
Keyser Posted April 11, 2013 Share Posted April 11, 2013 (edited) He's right^ Mr G you said that on a Public Forum you know!!!!!!!!!!!! @OP not the easiest space to dynamatt the centre divide is not solid and does not go end to end plus you have the petrol pump access panel in the bottom and a lot of wires in there. With a bit of work should be possible thou and some wadding would probably help in the back where the angle is tight? Let us know how it goes Edited April 11, 2013 by Keyser Quote Link to comment Share on other sites More sharing options...
un1eash Posted April 11, 2013 Share Posted April 11, 2013 The bose sub does have alot more to give if driven from an aftermarket headunit. Quote Link to comment Share on other sites More sharing options...
kris Posted April 15, 2013 Author Share Posted April 15, 2013 The bose sub does have alot more to give if driven from an aftermarket headunit. Already got one in He's right^ Mr G you said that on a Public Forum you know!!!!!!!!!!!! @OP not the easiest space to dynamatt the centre divide is not solid and does not go end to end plus you have the petrol pump access panel in the bottom and a lot of wires in there. With a bit of work should be possible thou and some wadding would probably help in the back where the angle is tight? Let us know how it goes I've done a bit of research on the American forums and I'm still deciding whether its less trouble to find a box with the right dimensions. I'll let you all know how it goes. Go for it, many laughed at me for getting a flat sub with no box but those thaf have heard it laugh no more I've seen these before, is that the earthquake one? Where is it mounted? Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted April 15, 2013 Share Posted April 15, 2013 Mine - Quote Link to comment Share on other sites More sharing options...
flamez Posted April 22, 2013 Share Posted April 22, 2013 (edited) I just tried to fit an idmax10 in as its a very good free air subwoofer, but because of the angle of the baffle and the depth of the sub the magnet hits the bottom and stops it going all the way in. I'm looking for a decent free air sub that isnt too deep, but in the meantime im gonna try a cheapo one once i get my amp in to see how it rattles first. Edited April 22, 2013 by flamez Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted April 22, 2013 Share Posted April 22, 2013 Would one of them underseat subwoofers work in the OEM sub location? Quote Link to comment Share on other sites More sharing options...
kris Posted April 22, 2013 Author Share Posted April 22, 2013 Would one of them underseat subwoofers work in the OEM sub location? Quite possibly, I would have to look at the dimensions. I do they sound good? Quote Link to comment Share on other sites More sharing options...
Plummerman Posted April 22, 2013 Share Posted April 22, 2013 I've currently got this sat in my garage ready to try out.. I've got a feeling it may shake the @*!# out of the rear panels as it bolts into the space where the Bose sub sat.. But hey it might not too... Will be finding out very shortly tho... http://www.ebay.co.uk/itm/Nissan-350z-Coupe-Custom-Sub-Box-Subwoofer-Enclosure-/250664954351 Quote Link to comment Share on other sites More sharing options...
kris Posted April 22, 2013 Author Share Posted April 22, 2013 Looking forward to seeing if that box is any good. Quote Link to comment Share on other sites More sharing options...
kris Posted April 22, 2013 Author Share Posted April 22, 2013 (edited) . Edited April 22, 2013 by kris Quote Link to comment Share on other sites More sharing options...
Plummerman Posted April 22, 2013 Share Posted April 22, 2013 Mix bag of reviews on my350 but then again there is some angry ice heads on there.. Suppose it depends on how much bass you want It's a sealed box for a start, that hole on the side isn't a port, it's a cabling hole.. So I've got to get a sub capable of working in a sealed environment with a max of 6" depth so the bass isn't going to be earth shattering.. But then again my days of booming jungle @ a K of of sound in a metro are over with Quote Link to comment Share on other sites More sharing options...
kris Posted April 22, 2013 Author Share Posted April 22, 2013 I'm sure of you dynamat the inside of the Bose space it would be fine. Yea on my350z even if your right your wrong! I'm not after window shaking bass, just clear punchy bass. Quote Link to comment Share on other sites More sharing options...
Plummerman Posted April 22, 2013 Share Posted April 22, 2013 That's the plan bud Bought the "full car" kit.. 6 sheets I think, just going to lay it everywhere I can.. And hope for the best. I was looking at the JL range.. The angry across the pond wallas seem to rate them highly. And there quite reasonable on price as well Cheers Phil Quote Link to comment Share on other sites More sharing options...
kris Posted April 22, 2013 Author Share Posted April 22, 2013 I've always had good experience with JL subs, looking forward to seeing your review 1 Quote Link to comment Share on other sites More sharing options...
Dblock Posted April 23, 2013 Share Posted April 23, 2013 That's a shame about the idmax they are awesome. Quote Link to comment Share on other sites More sharing options...
flamez Posted April 23, 2013 Share Posted April 23, 2013 That's a shame about the idmax they are awesome. yep i'm guessing you visit talkaudio lol. I know i'm so gutted it didn't fit 1 Quote Link to comment Share on other sites More sharing options...
Cozzi Posted July 9, 2013 Share Posted July 9, 2013 Has anyone had any further reports/ideas on this? I have been looking at JL free air subs and want to know if ones had any successes? Quote Link to comment Share on other sites More sharing options...
flamez Posted July 9, 2013 Share Posted July 9, 2013 I tried it quickly and the metal baffle was all over the place as soon as any sub excursion happened Quote Link to comment Share on other sites More sharing options...
Cozzi Posted July 10, 2013 Share Posted July 10, 2013 The metal fixing plate? That could be secured further if needs be though i assume? 1 Quote Link to comment Share on other sites More sharing options...
flamez Posted July 10, 2013 Share Posted July 10, 2013 (edited) I guess it could, but the only free air sub i thought was worth using is an idmax10 unfortunately it hits the fuel tank with the magnet as its too deep. Which JL free air sub are you looking at? I have now removed the baffle and probably getting a box built to go in as there is a decent amount of space back there. Edited July 10, 2013 by flamez Quote Link to comment Share on other sites More sharing options...
Cozzi Posted July 18, 2013 Share Posted July 18, 2013 Has anyone used an after market headunit and amp on the OEM sub? I.e. more power through the sub than standard? Quote Link to comment Share on other sites More sharing options...
