tez162003 Posted April 9, 2013 Share Posted April 9, 2013 (edited) Up for sale are my Brembo Gran Turismo 4 Pot Brakes and 2 Piece Brake discs. These have larger 40mm and 45mm pistons over the OEM Brembos. I bought these a while back and spent a fair amount of money refurbishing them. But due to lack of money and lots of bills I have to sell them... Not cool... I bought these about 6 months ago, within the refurbish I: - sand blasted the calipers - split the discs and stripped the disc centres - had the calipers power coated white - had the disc centres powder coated black - fitted new piston seals - fitted new dust seals - fitted new 13.9 high tensile bolts that join the halves together - cleaned and scraped (with a fine blade) the piston edges of built up burnt on brake dust - new Brembo stickers - new cross over fluid pipes - rebuilt the 2 piece discs using existing bolts (cleaned) with new nyloc nuts and washers What you will get is: - 2x Fully built brake discs - 2x Fully built brake calipers (one is missing its bleed nipples I believe, but you can use the ones from OEM Brembo brakes, only use brembo brake bleed nipples as I found out they are different to others.) - 1x spare un-built brake caliper, - all the old seals and spare bits and pieces - 3x 350z caliper mounting brackets - 1x pair of OEM brake hoses - 1x single braided 350z brake hose - a set of high tensile nuts and bolts to mount the calipers to your hub The spare caliper is in pieces and has a cross threaded bleed nipple but with it never being repaired before you will be able to repair it if you ever need it. The discs could ideally do with a skim to level them out on the faces, the thickness of the thinnest disk is 31.62mm so you have plenty of thickness to skim away. 1 caliper does have a slight storage mark on it, but otherwise they are in good condition. See pictures below for picture of the mark. I have only ever test fitted these onto the car, as I managed to stupidly let the brake reservoir run dry I put the originals back on to go get the brakes bleed properly at Japex. I am after £425 collected or £450 posted for these. These kits retail new for an extortionate price of over $3500 so grab a bargain. Hopefully someone will want these on here before I end going to eBay. Also I have a rebuild thread here: http://www.350z-uk.c...rs/page__st__40 Picture time! Edited April 10, 2013 by tez162003 1 Quote Link to comment Share on other sites More sharing options...
Ceejay29 Posted April 9, 2013 Share Posted April 9, 2013 I don't think these will hang about for long! GLWTS Quote Link to comment Share on other sites More sharing options...
smudgedon Posted April 10, 2013 Share Posted April 10, 2013 PM'd Quote Link to comment Share on other sites More sharing options...
smudgedon Posted April 10, 2013 Share Posted April 10, 2013 Inbox is full mate, 1st dibs (to conform with the apparent "rules" on this forum) if you can PM me please 1 Quote Link to comment Share on other sites More sharing options...
The Bounty Bar Kid Posted April 10, 2013 Share Posted April 10, 2013 Inbox is full mate, 1st dibs (to conform with the apparent "rules" on this forum) if you can PM me please Stop being a little girl about that! Quote Link to comment Share on other sites More sharing options...
smudgedon Posted April 10, 2013 Share Posted April 10, 2013 Inbox is full mate, 1st dibs (to conform with the apparent "rules" on this forum) if you can PM me please Stop being a little girl about that! It's bull spunk and you know it "dibs" is what you use in the playground at school Quote Link to comment Share on other sites More sharing options...
Wasso Posted April 10, 2013 Share Posted April 10, 2013 Inbox is full mate, 1st dibs (to conform with the apparent "rules" on this forum) if you can PM me please Stop being a little girl about that! It's bull spunk and you know it "dibs" is what you use in the playground at school Well just make sure you use it! Remember there's a large number of people who fire questions but don't actually want them. Dibs, or yes please is normally a good indicator so that others are aware of your interest. Quote Link to comment Share on other sites More sharing options...
smudgedon Posted April 13, 2013 Share Posted April 13, 2013 SOLD to meeee Nice to meet ya Quote Link to comment Share on other sites More sharing options...
tanabe Posted April 14, 2013 Share Posted April 14, 2013 they look clean, Quote Link to comment Share on other sites More sharing options...
