Welded diff
ChickenFB
Hi after welding my diff I want to remove the traction control fuse as keeps kicking in on 1st start up anyone have any ideas looked under kick plate an I no there is a box behind battery but if anyone can confirm before I start stripping down thank you
Is it for better / easier drifting? I assume you weld it so that the inside wheel still spins as fast as the outer? Please don't be mean to me if I'm totally wrong! :blush:
Close enough :thumbs:
Inside wheel out side wheel makes no odds if you weld the diff the back wheels are locked together always turn at the same speed - great for sliding - horrid to drive the car round corners slowly :lol:
Ok thanks for the info about location were to unplug.but it's a track car just for drifting an playing with an just after road test iv noticed its now pushing 26psi of boost an didnt evan have boost before an just from unplugging sensor wooop :) happy days
