Front sidelight bulb replacement
MickJ
Was going to change the front sidelight bulbs for something a little better and have just looked up in my 350z manual what is involved, have I read it right that you have to remove the wheelarch liners to access the back of the headlights or is there an easier way?
Mick, I can't remember about the sidleflight bulbs, but I knwo when I replaced the indicators, you can do without removing anything with some time, effort and patience!
But I just undid the bolt at the back of the headlight, holding it in..... (you see when you open bonnet)...... then did it that way as gave a bit of play....
So assuming it would be same, but someone will confirm I'm sure
be careful when withdrawing the bulb also., I dislodged my winker bulb when removing it,and it ended up lose inside the headlight unit :blush: , and ended up taking out the headlight unit complete to shake out the bulb.. :headhurt: wich involved removing bumper
one of my LEDs has failed, I got these at least 2 years ago, a cluster of 5 leds on every lamp, very nice and bright (blueish tinge same as the xenons, very nice) are they the same as yours? I need to buy a replacement
Yes, I have some blue LEDs I wanted to fit, but don't know if I can be bothered now, think I will go down the pub instead!
Got them from this chap on Ebay: 130102009298
