Supratad Posted April 5, 2013 Share Posted April 5, 2013 Today, I've had my discs skimmed and received new pads and shims from Alex, but what is the little stud for on my Brembo discs? And..... there is only one on the O/S disc, and just a threaded hole on the N/S disc, surely both sides should have one, shouldn't they? Aaaand....is there a previous thread on drum brake handbrake setup, re the barrel adjuster? Quote Link to comment Share on other sites More sharing options...
Keyser Posted April 5, 2013 Share Posted April 5, 2013 The stud is so you don't put the wheels on the wrong way round - front to back most owners just remove when they fit aftermarket wheels. Ref the handbrake adjust until the rear disk/drum slides on - test handbrake - if further adjustment is required line the hole in the disk up with the handbrake barrel adjuster and using a large flat bladed screwdriver move the adjuster - check handbrake - realise you moved the adjuster the wrong way and try again - repeat on both sides until happy. Please do this with both back wheels in the air and the car out of gear Quote Link to comment Share on other sites More sharing options...
Chris-6950 Posted April 5, 2013 Share Posted April 5, 2013 Could be wrong but I thought the stud was for loosening discs that had got jammed on the wheel hub. On mine you could unscrew the stud and a rubber(?) sleeve came off, then just screw the stud back in and eventually the disc just pops off. I had one on each disc. Worked really well. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted April 5, 2013 Share Posted April 5, 2013 no its as Keyser said Quote Link to comment Share on other sites More sharing options...
Supratad Posted April 5, 2013 Author Share Posted April 5, 2013 Thanks for answering. Do you mean, to prevent someone putting the back wheels on the front, or putting the wheel on so the inside faces out? Quote Link to comment Share on other sites More sharing options...
Keyser Posted April 5, 2013 Share Posted April 5, 2013 (edited) Thanks for answering. Do you mean, to prevent someone putting the back wheels on the front, or putting the wheel on so the inside faces out? Front to back I don't think you could put them on inside out even on purpose and if anyone did it by mistake I'm surprised they made it past puberty Edited April 5, 2013 by Keyser 1 Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted April 6, 2013 Share Posted April 6, 2013 Only stud near my Zed is the one driving it 1 Quote Link to comment Share on other sites More sharing options...
Keyser Posted April 6, 2013 Share Posted April 6, 2013 Only stud near my Zed is the one driving it This is of course a matter of opinion Quote Link to comment Share on other sites More sharing options...
Ekona Posted April 6, 2013 Share Posted April 6, 2013 I had no idea you lent your car out, Dave. 1 Quote Link to comment Share on other sites More sharing options...
