scottyp Posted April 4, 2013 Share Posted April 4, 2013 Right, dismantled my dash console last night in preperation for some wrapping - pics to follow if it goes as planned! However... lookng at the console, (air con controls especially!) I'm wondering how to start to cover the curve of the panel? Do I start in the middle and wrap down over the edges, or start on the side and stretch over to the other side? and how do I avoid the creasing of the film? (hairdryer?) Any help or pointers welcome - if its any consolation I'm the same with my xmas presents, usually more tape than paper! Quote Link to comment Share on other sites More sharing options...
14N Posted April 4, 2013 Share Posted April 4, 2013 Here's mine: Start in the middle and wrap over the edges. The vinyl will stretch round the corners - heat is your friend here 1 Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted April 4, 2013 Share Posted April 4, 2013 Always start in the middle and work out. A heat gun will work wonders, I have one without a heat control, but I turn it on and just flick the gun over the wrap to warm it a touch. You want a nice bit of stretch to follow the curves and keep creases out, but not so much that the vinyl will want to retract once it cools down. It will take a couple of goes, but it's not too difficult once you get the hang of it Quote Link to comment Share on other sites More sharing options...
Ceejay29 Posted April 4, 2013 Share Posted April 4, 2013 What happens if your initial attempt is a failure? Is it easy to pull off and re-position? I am tempted but will probably make a pigs ear of it! Quote Link to comment Share on other sites More sharing options...
Vlad Posted April 4, 2013 Share Posted April 4, 2013 I did mine as well...was a bit of a b*tch, but got there in the end! Here's mine: Start in the middle and wrap over the edges. The vinyl will stretch round the corners - heat is your friend here How did you do yours around dials? Did u just cut it around the edge? I cut mine and it didn't go perfectly to the plan lol Quote Link to comment Share on other sites More sharing options...
14N Posted April 4, 2013 Share Posted April 4, 2013 What happens if your initial attempt is a failure? Is it easy to pull off and re-position? I am tempted but will probably make a pigs ear of it! It is easy to peel off. As Dedman said, it's not too difficult, once you get the hang of it. I just used a hairdryer as my heat source and it worked fine. The gear/heater control surround is a good piece to get started with. It's easy to remove and the shape makes it a good piece to get some practice on. One good thing about wrapping is it's not permaneny and easily reversible if it goes belly up. Make sure you're in a tolerant, patient mood before you start and if the wrap you're using is textured, expect sore thumbs by the time you've finished 1 Quote Link to comment Share on other sites More sharing options...
Vlad Posted April 4, 2013 Share Posted April 4, 2013 What happens if your initial attempt is a failure? Is it easy to pull off and re-position? I am tempted but will probably make a pigs ear of it! Yea, use heat gun/hair dryer to warm it up slightly, so glue melts a little bit, pull it off and try again! Can't do many "pull offs" tho 1 Quote Link to comment Share on other sites More sharing options...
14N Posted April 4, 2013 Share Posted April 4, 2013 How did you do yours around dials? Did u just cut it around the edge? I cut mine and it didn't go perfectly to the plan lol I assume you mean the 3 at the top? I removed the dials (they're screwed and plastic riveted) and then cut around the bottom part. There is a small 'lip' in the p[lastic that I followed with a stanley blade. 1 Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted April 4, 2013 Share Posted April 4, 2013 I assume you mean the 3 at the top? I removed the dials (they're screwed and plastic riveted) and then cut around the bottom part. There is a small 'lip' in the p[lastic that I followed with a stanley blade. They look really smart too 1 Quote Link to comment Share on other sites More sharing options...
Vlad Posted April 4, 2013 Share Posted April 4, 2013 How did you do yours around dials? Did u just cut it around the edge? I cut mine and it didn't go perfectly to the plan lol I assume you mean the 3 at the top? I removed the dials (they're screwed and plastic riveted) and then cut around the bottom part. There is a small 'lip' in the p[lastic that I followed with a stanley blade. Yea, them ones! I tried same...cutting around the edge of that lip...but didn't go to well...I suppose it was late, I was tired and patience and me not best friends haha will re-do it when I get time! Lol 1 Quote Link to comment Share on other sites More sharing options...
14N Posted April 4, 2013 Share Posted April 4, 2013 Yeah, it's not a quick job and you do need a massive dose of patience! Mine isn't perfect, but I'm happy with how it cane out. Quote Link to comment Share on other sites More sharing options...
scottyp Posted April 4, 2013 Author Share Posted April 4, 2013 excellent, thanks for the advice - hopefully I'll have some pics tomorrow if it goes well 1 Quote Link to comment Share on other sites More sharing options...
scottyp Posted April 5, 2013 Author Share Posted April 5, 2013 Well, intake my hat off to those that have managed to wrap the console! Spent a few hours last night on the bottom section - and I have to say it looks like something a school kid knocked up for an end of term project I think it's something to do with my big hands or lack of co-ordination, but may have to bite the bullet and fork out for the stick on covers... Quote Link to comment Share on other sites More sharing options...
14N Posted April 5, 2013 Share Posted April 5, 2013 Oh dear, but I'm afraid I did lol at your school end of term project analogy Where are you located Scott? There might be someone local to you that's had a go at wrapping that might be able to give you a hand. Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted April 5, 2013 Share Posted April 5, 2013 Triple Gauges is the most PITA bit, the rest is fairly easy, did mine in 3M Di-NOC the first time, then re-did it with Hexis CF vinyl Quote Link to comment Share on other sites More sharing options...
scottyp Posted April 8, 2013 Author Share Posted April 8, 2013 I'm down in Taunton - just deciding wether or not to order some more and have another shot! Quote Link to comment Share on other sites More sharing options...
scottyp Posted April 19, 2013 Author Share Posted April 19, 2013 right - never one to be demoralised or give up i've got something new to try for the weekend! Got some alcantara type adhesive film and going to try and cover some of the larger exspanses of the dash for a luxury GT feel Pictures of me sobbing amongst sticky back plastic on monday! Quote Link to comment Share on other sites More sharing options...
cs2000 Posted April 19, 2013 Share Posted April 19, 2013 good luck, could look very nice Quote Link to comment Share on other sites More sharing options...
14N Posted April 19, 2013 Share Posted April 19, 2013 Sounds interesting. Fingers crossed for you Scott, we're all rooting for you. Quote Link to comment Share on other sites More sharing options...
Dblock Posted April 19, 2013 Share Posted April 19, 2013 I need to try a bit of wrapping. I know I'd be terrible though Quote Link to comment Share on other sites More sharing options...
scottyp Posted April 19, 2013 Author Share Posted April 19, 2013 My mate told me its because white men can't (w)rap - but I think he was just being culturally offensive! 1 Quote Link to comment Share on other sites More sharing options...
Fluke Posted April 19, 2013 Share Posted April 19, 2013 How did you find the Hexis when com paired the the Di-noc? Quote Link to comment Share on other sites More sharing options...
Chris`I Posted April 19, 2013 Share Posted April 19, 2013 right - never one to be demoralised or give up i've got something new to try for the weekend! Got some alcantara type adhesive film and going to try and cover some of the larger exspanses of the dash for a luxury GT feel Pictures of me sobbing amongst sticky back plastic on monday! Hope its UV resistant, not like the stuff I got off eBay and used in my old 350z which faded in the sun Quote Link to comment Share on other sites More sharing options...
scottyp Posted April 19, 2013 Author Share Posted April 19, 2013 Ah - good point, I'll double check. Would be gutting to get it covered well and then it fades! Quote Link to comment Share on other sites More sharing options...
cs2000 Posted April 19, 2013 Share Posted April 19, 2013 How did you find the Hexis when com paired the the Di-noc? Im sure BM will be back but I'll chip in my 2p. The texture effect on both is similar, I preferred the 3M stuff though. It seemed to me to be much sticker, hexxis stuff does stick don't get me wrong, but the 3M is (IMO) better for interior wrapping, deals with tight radius's and edges better. On the outside of a car (or maybe larger internal pieces) the hexxis stuff is better however as its more easy to reposition and it does handle heat a little better than the 3M which in itself does a pretty good job. horses for courses I think... Quote Link to comment Share on other sites More sharing options...
