Luke0549 Posted March 28, 2013 Share Posted March 28, 2013 Right here goes ATM I have Fronts - 225/50/17 Rears - 235/50/17 Does it matter if ibuy 225/45/17 and 235/45/17? Also, can I run 235/45/17 all round? It's just I want Goodyear eagle f1s but they not that common in 50. Cheers Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted March 28, 2013 Share Posted March 28, 2013 (edited) Pretty basic, but: http://www.willtheyfit.com/ and www.etyres.co.uk/tyre-size-calculator.htm Edited March 28, 2013 by Dedman Quote Link to comment Share on other sites More sharing options...
Ekona Posted March 28, 2013 Share Posted March 28, 2013 Right here goes ATM I have Fronts - 225/50/17 Rears - 235/50/17 Does it matter if ibuy 225/45/17 and 235/45/17? Also, can I run 235/45/17 all round? It's just I want Goodyear eagle f1s but they not that common in 50. Cheers Dropping a profile may mean you have TCS issues. Running the same size all round means you're going to get some intense oversteer, which means the back end is likely to want to overtake the front very easily, not something I'd recommend Quote Link to comment Share on other sites More sharing options...
Luke0549 Posted March 28, 2013 Author Share Posted March 28, 2013 Right so that clears that one up then! Quote Link to comment Share on other sites More sharing options...
ianphampton Posted March 28, 2013 Share Posted March 28, 2013 I bought 225/45/17 and 235/45/17 for my winter tyres as I couldn't get the 50 profiles in Winter Snow tyres. There are 3 issues 1) the speedo reads wrong by another 5% so it's normally about 8 or 9% out (checking against SatNav) 2) The TCS gets upset if you really give her some beans. It's OK 99% of the time - on winter tyres I wasn't too concerned as I don't drive hard on winter tyres - if you're buying these for summer you may have it crop up a bit more. You can avoid all the TCS issues though - by turning it off. Then it never trips you up 3) As the rolling radius is small (see 1) above) you travel more wheel rotations for any distance so you'll rack up more miles on your odometer. Of course, it's only 5% but - Apart from that - you CAN get away with it. What you MUST NOT do is mix profiles - if they're all 45 then at least the fronts and the rears are in sync. If you put 50 profile on the rear and 45 on the front the TCS will throw a fit. If you put 50 profile on the LHS and 45 profile on the RHS I suggest you apply for sectioning under the mental health act. Quote Link to comment Share on other sites More sharing options...
Ebized Posted March 28, 2013 Share Posted March 28, 2013 Better still, see if you can pick up some 18" wheels and tyres and you can then either flog the 17" that are sought after for winter use or keep them for that purpose yourself, all if money allows or course Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted March 28, 2013 Share Posted March 28, 2013 I'd buy some cheap 17's as skid rims Quote Link to comment Share on other sites More sharing options...
Dblock Posted March 28, 2013 Share Posted March 28, 2013 Right here goes ATM I have Fronts - 225/50/17 Rears - 235/50/17 Does it matter if ibuy 225/45/17 and 235/45/17? Also, can I run 235/45/17 all round? It's just I want Goodyear eagle f1s but they not that common in 50. Cheers Dropping a profile may mean you have TCS issues. Running the same size all round means you're going to get some intense oversteer, which means the back end is likely to want to overtake the front very easily, not something I'd recommend No, it wont lol. Quote Link to comment Share on other sites More sharing options...
docwra Posted March 30, 2013 Share Posted March 30, 2013 If you put 50 profile on the LHS and 45 profile on the RHS I suggest you apply for sectioning under the mental health act. It actually makes the car pull to the one side when you accelerate, quite amusing for a short while Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted March 30, 2013 Share Posted March 30, 2013 How about if you put a 45 & 50 profile on the front and rear but on opposite sides... Quote Link to comment Share on other sites More sharing options...
Ekona Posted March 30, 2013 Share Posted March 30, 2013 No, it wont lol. Yes it will more lol. Quote Link to comment Share on other sites More sharing options...
Dblock Posted March 30, 2013 Share Posted March 30, 2013 No, it wont lol. Yes it will more lol. Have you tried it? Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted March 31, 2013 Share Posted March 31, 2013 No, it wont lol. Yes it will more lol. Have you tried it? (pulls up chair) Quote Link to comment Share on other sites More sharing options...
