P15UL T Posted April 25, 2007 Share Posted April 25, 2007 with the brembo set up can you get away with 28 front and 23 rear - if so what do they look like - ie stick in or out ?? cheers in advance Paul Quote Link to comment Share on other sites More sharing options...
rickya Posted April 25, 2007 Share Posted April 25, 2007 28 front is gona be too much into the front arches (wont look good), Brembo clearence will depend more on alloy shape etc ; 23 rear is good Quote Link to comment Share on other sites More sharing options...
Rob_Quads Posted April 25, 2007 Share Posted April 25, 2007 All comes down to the design of the wheel. 28 on one wheel would clear but then on another it might not. Generally 28 is quite high and will probably sit fairly tucked in at the front. Quote Link to comment Share on other sites More sharing options...
Sarnie Posted April 25, 2007 Share Posted April 25, 2007 How about +23 and +21 Quote Link to comment Share on other sites More sharing options...
Jacko Posted April 26, 2007 Share Posted April 26, 2007 How about +23 and +21 Again, you can't just say an offset and whether it will look good. Needs to be taken in conjunction with the size of the wheel (width) and design..... Quote Link to comment Share on other sites More sharing options...
Ian Posted April 26, 2007 Share Posted April 26, 2007 Ive got +22 front & rear and they fill the arches really well Any excuse for a pic Quote Link to comment Share on other sites More sharing options...
P15UL T Posted April 26, 2007 Author Share Posted April 26, 2007 very sweet rims mate Quote Link to comment Share on other sites More sharing options...
Adam@Z1auto.com Posted April 29, 2007 Share Posted April 29, 2007 All comes down to the design of the wheel. 28 on one wheel would clear but then on another it might not. Generally 28 is quite high and will probably sit fairly tucked in at the front. offset and width go absolutely hand in hand one can't say how a +28 will look without saying how wide it is It also depends on the tire (both size and brand) IE - an 18x8.5 with a +28 and 18x9.5 +28 look vastly different (9.5 will sit out 1/2 inch more) despite the offset being the same for example - this is 18x8.5 +20 up front (9.5 +20 out back) An 18x9 with a +26 would sit exactly the same in relation to the fender of the car this is a good offset calculator http://marksink.com/tire_wheel_offset/offset.html Quote Link to comment Share on other sites More sharing options...
P15UL T Posted April 29, 2007 Author Share Posted April 29, 2007 here is the widths of the rims - dont have tyres on them so what would you reccomend if they will indeed fit ? 19x9.5 front offset 28 (will they clear the brembos) 19x10.5 rear offset 22 cheers in advance ps - that is a sweet ride adam, is it yours ? Quote Link to comment Share on other sites More sharing options...
Trev-the-Rev Posted April 30, 2007 Share Posted April 30, 2007 Useful calculator Adam. Quote Link to comment Share on other sites More sharing options...
Adam@Z1auto.com Posted April 30, 2007 Share Posted April 30, 2007 they will fit yes I'd run 255 or 265/30/19 up front and 285/30/19 out back (might need to roll the rear fenders) Yes that was mine, taken 2 summers ago...looks different now though ) Quote Link to comment Share on other sites More sharing options...
Rob_Quads Posted April 30, 2007 Share Posted April 30, 2007 My comment presumed you would be going with fairly standard width of wheels i.e. 8.5" Quote Link to comment Share on other sites More sharing options...
P15UL T Posted April 30, 2007 Author Share Posted April 30, 2007 i really quite thick when it comes to this.....but i take it the wheels would stick out further dues to the increase in wheel width but also stick in further due to the difference in offset ??? thanks for your help guys Quote Link to comment Share on other sites More sharing options...
