Toad Posted March 25, 2013 Share Posted March 25, 2013 ok changed strutts sgs one's and it stays open, but still wont clear so need two hands to get it started, so tried two rubber washers each side in springs and 2 pennies, works for a bit but gets worse over time - i think the rubber washers get compressed and don't want to take them out as painwork gets damaged with just pennies, so have just taken the weight out and still need to press twice and it's 50/50 if it clears enough to open or not so can lift with one hand, so what's left - new springs ? Quote Link to comment Share on other sites More sharing options...
glrnet Posted March 25, 2013 Share Posted March 25, 2013 for new springs Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted March 25, 2013 Share Posted March 25, 2013 I've had new sgs struts & changed both springs. Still does it for me too. Haven't removed the weight yet though which will be my next thing I think Quote Link to comment Share on other sites More sharing options...
JackStrong Posted March 25, 2013 Share Posted March 25, 2013 removing the weight proved to work well for me. It only weighs 1.1kg but helps loads Quote Link to comment Share on other sites More sharing options...
4RE Leather Posted March 25, 2013 Share Posted March 25, 2013 removing the weight proved to work well for me. It only weighs 1.1kg but helps loads Drop it on ya toes and you won't think its only 1.1kg:) Quote Link to comment Share on other sites More sharing options...
leightonjames Posted March 25, 2013 Share Posted March 25, 2013 Toad - your story describes my exact situation over the last couple of days! I've now got a rubber grommet (about the thickness of three coins) and three coins and it seems okay but still not right! Hope somebody has a solution, it's annoying! Quote Link to comment Share on other sites More sharing options...
Toad Posted March 26, 2013 Author Share Posted March 26, 2013 just purchase new spring of Alex, so will let you know james Quote Link to comment Share on other sites More sharing options...
danpollard Posted March 26, 2013 Share Posted March 26, 2013 Are you guys referring to the "double opening" issue (i.e. that the tailgate pops on the first press, but doesn't clear the latch). I'd seen on the common issues thread that you could just pad it out with a bit of foam to solve the issue. I'll also be intrigued if new springs solve it, as both of mine have exhibited this issue, and it is annoying! Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted March 26, 2013 Share Posted March 26, 2013 If new springs solve the issue, especially after new struts too then lucky you. Still currently pissing me off Quote Link to comment Share on other sites More sharing options...
hawker1986 Posted March 27, 2013 Share Posted March 27, 2013 Indeed, ive had new struts a while as the boot kept falling down :S. But ive just replaced the springs with new ones from the caped one and its not helped at all. Old ones had foam filling them and that didn't do it either. May have to try and remove the weight and see. Quote Link to comment Share on other sites More sharing options...
Flex Posted March 27, 2013 Share Posted March 27, 2013 Yeah so either the penny trick (cheap fix) or splash out the 27 ish notes to Alex, sorted Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted March 27, 2013 Share Posted March 27, 2013 The penny trick is something I'm not willing to try, I have the luck that would let it mark my paint. Ill try the weight when I get the chance Quote Link to comment Share on other sites More sharing options...
Flex Posted March 27, 2013 Share Posted March 27, 2013 The penny trick is something I'm not willing to try, I have the luck that would let it mark my paint. Ill try the weight when I get the chance It's all good bro, seriously give it a try. Quote Link to comment Share on other sites More sharing options...
Madhatter Posted March 27, 2013 Share Posted March 27, 2013 What spoiler do you have? I had this issue with the Nismo v1 spoiler and added 3p in each spring wrapped in insulation tap - still got the weight in and on original struts. Then I gumm'ed the spring rubbers hoping they don't damage the paint work and all is good so far. Another trick is to use sticky back foam cut in circles on the underneath where the springs land. They cushion the springs and though over time will wear, a sheet of this sticky foam will last a while to just replace when/if. Used to do this on some of my previous cars to make sure the paintwork never got damaged. Quote Link to comment Share on other sites More sharing options...
Stutopia Posted March 27, 2013 Share Posted March 27, 2013 Weird madhatter, I was just thinking about this to give my boot release a little boost and protect the paint. Did a quick look for these on the 3M website, found some promising items in the "bumpon" section, but they come in packs of 3000! Anyone want 2998, 50p each. ;-) Quote Link to comment Share on other sites More sharing options...
Flex Posted March 27, 2013 Share Posted March 27, 2013 Weird madhatter, I was just thinking about this to give my boot release a little boost and protect the paint. Did a quick look for these on the 3M website, found some promising items in the "bumpon" section, but they come in packs of 3000! Anyone want 2998, 50p each. ;-) Tight bugger! Quote Link to comment Share on other sites More sharing options...
Stutopia Posted March 27, 2013 Share Posted March 27, 2013 Changed the plan to some sort of self-adhesive 32mm x 6mm neoprene strip, assuming it's not a total omnishambles from e-bay, I'll gladly punt the remaining 9.5 meters (must allow for repeated ****-ups) on to anyone who wants, gratis. Quote Link to comment Share on other sites More sharing options...
Toad Posted March 27, 2013 Author Share Posted March 27, 2013 sigh new springs arrived put in car and they didn't make a scrap of difference - that's weight removed strutts and spring replaced now - complete and utter waste of money, very pi**ed off with the design of this boot Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted March 27, 2013 Share Posted March 27, 2013 sigh new springs arrived put in car and they didn't make a scrap of difference - that's weight removed strutts and spring replaced now - complete and utter waste of money, very pi**ed off with the design of this boot Yeah you'd hope that after spending £100 on parts the thing would work wouldn't you! Quote Link to comment Share on other sites More sharing options...
Madhatter Posted March 27, 2013 Share Posted March 27, 2013 SuperStu - I used something like this: http://www.ebay.co.uk/itm/2x-Closed-cell-Sticky-backed-foam-thick-high-density-water-thermal-130x200x5mm-/130766470193?pt=UK_In_Car_Technology&hash=item1e7249fc31 Quote Link to comment Share on other sites More sharing options...
Stutopia Posted March 27, 2013 Share Posted March 27, 2013 Nice one Madhatter. I ordered the rubber tape before seeing this, but if that fails ill try the sticky back foam. Ta Quote Link to comment Share on other sites More sharing options...
amstrange1 Posted April 8, 2013 Share Posted April 8, 2013 (edited) This is what I did to mine: The springs on mine were fine 'til I fitted new SGS gas struts, after which the springs were no longer strong enough to clear the boot latch. The fabled 'penny trick' was only partially successful, so I tried the above method instead. They're little self-adhesive nipples used by kit car builders and the like, added to the end of the spring. By making the spring assembly 3-4mm longer with this nipple, the spring is compressed more when closing the boot and thus the additional pre-load helps to pop the boot open properly. Took all of 20 seconds to fit, and worked a treat. Edited April 8, 2013 by amstrange1 2 Quote Link to comment Share on other sites More sharing options...
Shaun1982 Posted April 8, 2013 Share Posted April 8, 2013 Where can you get those dude? Quote Link to comment Share on other sites More sharing options...
Stutopia Posted April 8, 2013 Share Posted April 8, 2013 There's boot loads of adhesive rubber feet on ebay. I nearly bought a batch but went for some adhesive Kevlar to stick to the "landing pad" instead. If that fails ill be feeting up as the next ploy. Quote Link to comment Share on other sites More sharing options...
amstrange1 Posted April 8, 2013 Share Posted April 8, 2013 I got mine from someone at work, I'll see if I can find out the supplier - these are automotive grade parts, so the adhesive's half-decent. Quote Link to comment Share on other sites More sharing options...
